K series modding and tuning
Replied by Diesel Destroyer on topic K series modding and tuning
Posted 11 years 5 months ago #122624
According to Scholar the torque curve should be dead straight
It would pull right through to 9,600.. but Id need a billet crank and they aint cheap
The box was re-built using steel caged bearings and tapered bearings on the torsion diff
If you want something build properly (fingers crossed) go to a reputable K series engine builder and not someone who will just paint the block silver with a rattle can :omg:
Another thing Ive learnt is.. when fitting a new fly wheel NEW flywheel bolts MUST be used.. Wonder whats in my mates :-?
Hellier only ever uses OME stretch head bolts.. and again these need to be new during the engine build
Sadly though none of the above comes cheap :(
Posted 11 years 5 months ago #122625
helsbyman wrote: Hi D D I had my head done by Sabre 1 1/2 yrs ago good man
Roger knows his stuff..
Personally Id only use either Dave, Roger or Jason for K series engine modding..
All three very experienced
Scholar do complete engine builds.. and head porting and polishing but not seen one of their heads
Replied by steve51800 on topic K series modding and tuning
Posted 11 years 5 months ago #122627
Very impressive, out of curiosity what gains in BHP do you envisage, and how much has this cost, not including a price on your time, as a cost per bhp. Dont worry though, if you dont want to divulge the costs I fully understand!!
"If it all seems under control, you're just not going fast enough!" Mario Andretti
Posted 11 years 5 months ago #122628
Some useful links
Scholar Evo2
http://www.scholarengines.co.uk/EVO2%20block.htm
Hellier
http://hellierperformance.com/
Dave Andrews site
http://www.dvapower.co.uk/
Roger at Sabre
http://www.sabre-heads.co.uk/1.html
Emerald
http://www.emeraldm3d.com/
Piper cams
http://www.pipercams.co.uk/pipercams/www/index.php
Vernier (via QED)
http://qedmotorsport.co.uk/the-engines/vauxhall-xe-c20xe/vernier-pulleys
Elise Parts
http://www.eliseparts.com
Posted 11 years 5 months ago #122629
steve51800 wrote: Very impressive, out of curiosity what gains in BHP do you envisage, and how much has this cost, not including a price on your time, as a cost per bhp. Dont worry though, if you dont want to divulge the costs I fully understand!!
The whole lot.. as in the first pics.. including the subframe blasting etc.. is probably around £7k..
:omg:
The break down is very very extensive so I wont go into it
As for expected power/torque.. anyones guess.. but should be around the 200Bhp mark
The engine had all new bearings/shells and every seal and gasket is new
Hellier did all of the bottom end balancing and did some machining too..
I paid labour for the engine build and gearbox as Im not competent in those fields
The engine is almost as new.. only the crank and rods are original
Yes its a hell of a lot of money to gain a little extra BHP...
But its only money :bust:
This includes buying the TF160 lump (47,000 miles) with loom and ECU for £600
I could do a list of bits in the engine.. but it will be stupid long..
Last Edit:11 years 5 months ago by Diesel Destroyer
Last edit: 11 years 5 months ago by Diesel Destroyer.
Posted 11 years 5 months ago #122630
I know some will be amazed at the price... but this is almost a brand new engine
This engine has been 'properly' re built
The costs soon add up
The custom anti roll bar was £150
The custom sphere hoses £25 each
The nuts and bolts on the rear subframe around £40
And thats without even touching the engine/box
The rear hubs are being custom machined to make them stronger.. the rear brakes custom (312mmx25mm vented discs with 2 pot callipers) five stud hubs.. all new ball joints and bearings
The rear tie bars are being custom made
Cost is now irrelivant lol
Posted 11 years 5 months ago #122632
Still to buy
Roose sillicone hoses
Laminova oil cooler
8mm silicone HY leads
2x new coils
Denso irridium plugs
High pressure fuel pump
Pressure regulator
Posted 11 years 5 months ago #122636
Ive seen a few people before quoting this '188' figure
Lotus developed the K series and made a VPHD version which apparently made 188 Bhp
Most 160 owners will likely see around 150-158 from their standard engines
Exahust and air filter/inductions would see that figure rise.. but not 188
DVA (Dave Andres) is one of the most resepceted names involved with K series engines.. his web site lists the mods needed to see 180+ Bhp
Remember DVA is talking about ACTUAL not 'guesstimate'
Rolling road sessions are a great way off seeing EXACTLY what your engine makes
'feels fast' and 'I reckon' are no match for a properly calibrated rolling road
Posted 11 years 5 months ago #122642
http://www.wilcoxengines.co.uk/kseries.htm
Replied by helsbyman on topic K series modding and tuning
Posted 11 years 5 months ago #122655
Hi d d rolling roads aren't that good as you may see 100bhp day 1 and day 2 110bhp on the same car/engine
Posted 11 years 5 months ago #122657
I totally agree..
The general is up to 10% out..
But certainly more accurate then guessing :bust:
My car will probably go to Emerald to be set up..
Their rolling road is calibrated..
Most decent rolling roads are calibrated.. but as above can be out by 10%
Thats why Ive previously suggested 1/4 mile days... No cheating them... The decent ones monitor the movement of your car.. so even setting off half a second slower on the lights doesnt affect your time
Replied by Tourbillon on topic K series modding and tuning
Posted 11 years 5 months ago #122664
My car is with Emerald this wednesday to have the ECU set up, expecting it will be a "Beast" on the drive home :-)
TB
Time to create page: 0.523 seconds
