Help with setting idle screw after I moved it
Replied by Ryan Poultney on topic Help with setting idle screw after I moved it
Posted 1 year 11 months ago #200588
Thanks for the quick reply David and welcoming me to the group,
I have just done what you said after start up revs are around 820 to 850 monitoring using obd app.
Thanks
Posted 1 year 11 months ago #200589
I also have on fault code for the cam shaft position sensor p0340
Replied by David Aiketgate on topic Help with setting idle screw after I moved it
Posted 1 year 11 months ago #200592
It should be pretty steady at 850 with a hot engine, certainly not as low as 820.
The following user(s) said Thank You: Ryan Poultney
Posted 1 year 11 months ago #200599
Thanks David it seems to be idling okay though and since cleaning the iacv it doesn’t try to stall when going from high idle when cold to normal idle.
I think I will leave it how it is for now.
Thank you for your help
Time to create page: 0.562 seconds
