Intermittent Heater Fan/Switch
![:-? :-?](/confuse.gif)
I agree with David, if the fault is with all speeds it's almost certainly not the resistor pack but a break elsewhere.
Robin
- the singing bush
Replied by the singing bush on topic Re:Re: Intermittent Heater Fan/Switch
Posted 10 years 10 months ago #124538![:) :)](/media/kunena/emoticons/8.png)
Replied by bensewell on topic Re:Re: Intermittent Heater Fan/Switch
Posted 10 years 10 months ago #124539the singing bush wrote: I'm sure there will be a better description but until then... Passenger footwell, remove glove box (carefully) then look for the 10mm single nut holding the air duct tube bolted near the bulkhead... Once undone, the ducting will be removable, look for a square shaped plug with what looks like a corner shaved off - it's held in by two Philips headed screws, unplug the plug and undo The wires - remove and you should have a rectangle shaped corner missing bit with some tarnished soldered coil type steel wire... The are the resistors - go for a ceramic replacement, the heat is warmer and they last longer
you'll need to unsolder and resolder etc - in the right order.
I can confirm that scotts work is still lasting now in his cast off / my gain 'Bogey' is very warm at the moment.
- the singing bush
Posted 10 years 10 months ago #124541![:) :)](/media/kunena/emoticons/8.png)
Posted 10 years 10 months ago #124542Please Log in or Create an account to join the conversation.
- the singing bush
Posted 10 years 10 months ago #124543Please Log in or Create an account to join the conversation.
