Air filter
Air filter was created by John Pell
Posted 11 years 5 months ago #125498
If I remove the air filter box what size is the inlet pipe for fitting a cone filter
Replied by Andy Lawrence on topic Air filter
Posted 11 years 5 months ago #125500
Most come with adaptor rings.
Think it's about 50mm
WHALE OIL BEEF HOOKED
Replied by John Pell on topic Air filter
Posted 11 years 5 months ago #125501
Thanks just tried ti have a look but its just getting a bit dark now I'm a bit thick but does it go onto the throttle body
Posted 11 years 5 months ago #125502
Yes, either direct or with an elbow.
Replied by Forrester on topic Air filter
Posted 11 years 5 months ago #125514
As Andy says the hose goes over the throttle body opening & secured with a Jubilee clip.
Presume you have the kit that includes 2 flexible tubes that draw air from underneath the car & blow onto the filter. These are secured by long cable ties to suitable body fittings, but the alignment needs checking every so often.
Posted 11 years 5 months ago #125546
Are you saying just putting a cone type filter on the end of the throttle body is not a good idea as will be using hot air from the engine ????
Replied by Tourbillon on topic Air filter
Posted 11 years 5 months ago #125551
John,
The cone filter straight to TB will give an improvement in performance but is limited by the fact it will draw in hot engine bay air. Ideally you want the Cone enclosed in some way with a pipe going to the side air intake, or in the case of K&N 2 pipes running out of the bottom of the engine bay and directed forwards. In my car I ran a large pipe (100mm) direct from the intake up to the cone filter, however I have scoops fitted so under driving conditions cooler outside air is forced into the engine bay and onto the K&N. This is not ideal... but does a job for a fraction of the cost of the full enclosed Cone filters with CAF.
TB
The following user(s) said Thank You: John Pell
Replied by helsbyman on topic Air filter
Posted 11 years 5 months ago #125552
your car is an "F" so a K&N cone will come with a rubber connect hose to connect the filter to the throttle body The only thing that is wrong with the kit as such is the connecting hose has a 70 degree turn in it and any turn creates a loss of power I think £ for£ per hp gained you are better off with a panel K&N filter as this is inclosed in the OE box you can then put a cold air feed into the OE box A panel filter is £38 for 4ish BHP or £90 for a cone for 7ish BHP
Posted 11 years 5 months ago #125554
Yes I agree a panel filter it is piper cross or K&N :-?
Posted 11 years 5 months ago #125555
I would go for K&N as they are the market leaders, the others copy them
Replied by cairnsys on topic Air filter
Posted 11 years 5 months ago #125557
John Pell wrote: Yes I agree a panel filter it is piper cross or K&N :-?
John
I have a K&N panel filter that I've just taken out of my mk1 F. It's only been on for about 1000 miles so is still pretty clean. You can have it if you want. PM me with your address and I'll put it in the post.
I changed it for a Pipercors PK091 cone filter that I got for £36 plus p&p from David Manners Group. This one doesn't have a cold air feed like the more expensive induction kits but I'm fairly convinced it gives more power than the KN panel,job. It's certainly NOISIER!
Robin
Replied by martin_bmth on topic Air filter
Posted 11 years 5 months ago #125563
Ive got my cone filter on the end of the original tubing. I think a few people run them like this. Sounds awesome but is apparently not so good for performance. Has been ok for me and not noticed any power loss in my driving.
Ive seen an article somewhere that u can use a paint can to make your own induction kit.. rather fancy trying that at some time.
Time to create page: 0.444 seconds
