Air filter
Replied by John Pell on topic Air filter
Posted 11 years 5 months ago #125564
Hi Martin did you have the alloy throttle body fitted or was in already on the car
Replied by Forrester on topic Air filter
Posted 11 years 5 months ago #125569
This is my set-up;
Posted 11 years 5 months ago #125570
This is my set-up;
Posted 11 years 5 months ago #125622
Now I can see what is ment about getting cold air to the cone filter from your pics it all makes sense now
Thanks for that
Replied by TruckerClarky on topic Air filter
Posted 11 years 5 months ago #125628
I fitted a vadar closed kit to my 95 F, makes a hell of a difference in both performance and noise..... ;) cold feed fed from passenger side vent thru to filter........quick tip. \i bought the cold feed pipe from B&Q for £8
The following user(s) said Thank You: John Pell
Replied by martin_bmth on topic Air filter
Posted 11 years 5 months ago #125645
The throttle body is a standard 48mm, car is 2001 so its alloy as standard. Ive got a nice 52mm one from Mr Maltby to go on when i get some time. :-)
Posted 11 years 5 months ago #125646
Martin I have sent you a PM about the throttle body
Replied by mgf bushdevil on topic Air filter
Posted 11 years 5 months ago #125799
All i put on mine was a cheap ripspeed stainless cone air filter onto a 52mm throttle body & as with truckerclarky bought a piece of ducting pipe from B&Q & put it to the side vent which now has the added air intake scoops hope this helps B)
Replied by cairnsys on topic Air filter
Posted 11 years 5 months ago #125802
mgf bushdevil wrote: All i put on mine was a cheap ripspeed stainless cone air filter onto a 52mm throttle body & as with truckerclarky bought a piece of ducting pipe from B&Q & put it to the side vent which now has the added air intake scoops hope this helps B)
What material is the ducting?
Posted 11 years 5 months ago #125805
Not 100% on the exact material but it's just flexi pipe in plastic almost the same as used by K&N hope this helps in some way
Posted 11 years 5 months ago #125810
Yes thanks! Will take a look to see what they've got in the morning.
Cheers....
Posted 11 years 4 months ago #125828
The stuff I got is like a strengthened aluminium foil type stuff, Its suitable for both hot air and cool air ventilation.
Time to create page: 0.442 seconds
