MG TF Link assembly-trailing rear suspension
MG TF Link assembly-trailing rear suspension was created by bugman23
Posted 11 years 3 months ago #126801
Hi, my MG friends,
i would like know if its possible to find this item (red circle) :
Replied by David Aiketgate on topic MG TF Link assembly-trailing rear suspension
Posted 11 years 3 months ago #126806
As far as I am aware, you can't get that rose joint separately. :nonod:
Replied by bugman23 on topic MG TF Link assembly-trailing rear suspension
Posted 11 years 3 months ago #126823
:doh: :doh: :doh: :doh:
I have put new ball joint in this...and if i can't find the center ball joint...i have spend my money for nothing...
Posted 11 years 3 months ago #126825
38G is not a polybush for put in this ???
Replied by Diesel Destroyer on topic MG TF Link assembly-trailing rear suspension
Posted 11 years 3 months ago #126826
Same sort of story on the F.. although the arms are shorter..
What it needs is someone to make custom arms where the ends can be sourced easily.. and swapped.. instead of buying new arms all the time..
:whistle:
Last Edit:11 years 3 months ago by Diesel Destroyer
Last edit: 11 years 3 months ago by Diesel Destroyer. Reason: Type editied.. before the spelling police get me
Posted 11 years 3 months ago #126827
bugman23 wrote: :doh: :doh: :doh: :doh:
Its not available.. for either F or TF..
You have to buy complete new arms... total joke aint it
I am going with M12 rose joints on custom made arms.. and swap the rose joints (McGill motorsport ones) every couple of years..
Posted 11 years 3 months ago #126829
Its home made arms by you ?
You think its possible to find a dealer who can made the same but for MG TF ?
Posted 11 years 3 months ago #126830
Not made by me..
A company in Evesham
I supplied an original arm and an M12 heavy pattern rose joint from McGill and they did the rest
Originally they were going to cut the ball off and machine a thread into the factory arm.. but were worried about strength so made new arms and machined threads into these.. The wall thickness is 5mm or 7mm or something..
Find a local friendly engineering company and ask them for a price..
I need stainless spacers each side of the rose joint but will get these turned up by my local man
The rose joints will have rubber boots fitted..
Ok not a cheap option to start with.. but from now on I can just swap ends instead of keep buying arms..
Posted 11 years 3 months ago #127055
I think its possible to find M12 heavy pattern rose joint for directly fit no ?
Time to create page: 0.594 seconds
