Answer required
I should of took a PICTURE
- Leigh Ping
- Online
John Pell wrote: I should of took a PICTURE
Perhaps we already have a pic of it in our guide for jacking up an MG. Take a look and let us know please.
Is it a gear cable or hand brake ????? :help:
Thanks for all your replies
They are cheap enough but you need to pop the ball joint off the bellcrank and then unscrew the ball joint end off the threaded of the cable. Someone actually cable tied a finger from a rubber glove in its place. It worked, plus you can pull the finger over the end without unscrewing it.
The end is held by a lock nut so you can use the locknut to mark the position where you need to re-screw the end after fitting the gaiter.
Incidentally if your reverse is a bit 'gratey' going in then screwing the end on by a further two turns will help with selecting reverse.
The gaiters are available from Rimmers, Brown and Gammon and Mike Satur has the as well I believe.
Good hunting
Robin
Robin
