RED TF
- GT MG SPARES LTD
I purchased and it sat in the unit until two weeks when i got it on the ramp and the subframes was a bit rusty and the engine creamed right up.
I purchased the Green 05 TF in pictures WITH ONLY 19000 MILES from insurance company and have swapped the complete subframes engine running gear effectively a 52 reg car sitting on 2005 running gear and the improved soft ride suspension.
I have informed DVLA of the engine change and now have another car in the garage i will probably never use.
The addiction goes on.
- Leigh Ping
Richard
- GT MG SPARES LTD
The hole partially showing in picture of bumper on car below is not even the threaded hole,just a hole below the threaded hole.The pictures below illustrate explain better.
- GT MG SPARES LTD
I am sure somebody on here will pop up with a way they got around the holes not lining up but if you are going to fit a LE500 style bumper the part number i used for the armature bar is below.
- Diesel Destroyer
Just done Quick-Spiders..
Quick etch prime and paint black and jobs a good en
- GT MG SPARES LTD
- Diesel Destroyer
Quick Spiders is the third ive done this way.. and the other two never commented on the bumper not lining up...
I took a totally different route on mine.. and scrapped the box section bumper carrier as it blocks the rad..
But then I have a fibre glass bumper that's a lot stiffer and is now carried from bottom edge
- GT MG SPARES LTD
The new bar centre to centre of the two threaded holes 19mm.David Aiketgate wrote: What's the actual difference between hole centres on the two armature bars? The bolt in the new bar makes it difficult to tell?
