MGF Rear Bumper Mesh
- Rich in Vancouver
If there was a flange around the openings it would be a breeze, but of course there isn't. :nonod:
I am wondering if anyone has any suggestions as to the best way to attach the mesh?
Cutting it to size and making holes for the exhaust and tow hook isn't a problem.
I am thinking of using angle brackets bolted to the bumper with the mesh bolted to the brackets unless someone has a way to attach brackets or a flange using adhesive. It would be nice to avoid having fasteners showing. If so which adhesive?
Any hints appreciated!
- Leigh Ping
Whiz used 'sealant' to hold his in place. Albeit in a different location. Here's the topic. Clickety click.
This is a mod which im going to do when i have sorted a few other things out but im going to use a repair putty. It comes in pellet form and you just mix it together between your fingers and basically stick it on. Ive used it before to repair all sorts of things and it works a treat as lasts forever. Paintable, sandable, waterproof and works on all sorts of materials. Always have a pack of this stuff in my toolbox. This pack was about £3 on ebay with £2 postage, Hope this helps.
- Rich in Vancouver
- adamelphick
- John and Sue
If you remove the rear bumper you should see tags with 'oles in around the opening. You'll need some fold-over clips for self tappers, I know them as spire clips from days of old.
Simply cut the mesh oversize, slip t he clips over the tabs and screw the mesh on.
Worth taking the bumper off rather than gobbling the mesh on with donkey-snot.
Over a couple of years ago I fitted SS mesh using a flexible filler/sealant, think it was bathroom sealant from memory, just something I had left over in the garage. Wedged it in place until the sealant set and it's still there. :broon:
I didn't remove the bumper as I didn't go around the tail pipes.
- John and Sue
PQD44 wrote: On the MGF there are no mounting holes for a rear mesh, unlike the TF.
Soz, I wasn't aware that the F didn't have the mesh tags to do a proper job.
Bog sealant/Gun-Gum/Wrigleys Spearmint it is then. :broon:
- Rich in Vancouver
PQD, Not cutting the mesh to fit around the tailpipes makes sense. It's easier and less chance or rattling. I'll have to give it a good look. :broon:
I use sikiflex as it's designed for this sort of thing and cheap from work.
