Reversing lights
So I picked up some underpriced three ring lights off of flebay ( the black ones not the bilingy chrome ones) knowing they had a stud missing. Several layers of araldite later and hey presto ready to fit, easy change no hassle. Then I get my good lady to check them, everything ok but no reverse lights! Plugged the old lights back in, still no lights. :bang:
Lights themselves eliminated, where does a novice start, I suspect there is a switch but where? How do I get to it? Would they be on its own fuse? Any thoughts appreciated. :beer:
Fuse 16 seems to be reverse in conjunction with stop lights so if those are working at least you can eliminate the easiest problem to solve.
Without sounding daft, is the switch under the car, in through the top, left, right or middle? I don't normaly venture into engines! :doh:
- The driving dutchman
