Broken rear window replacement
:oops: :oops: :oops:
So wheres the best place to get a replacement? Theres a couple of people on ebay that say you post us your old one and they fit a new screen and post it back, one is £40 + P&P the other is £50 + P&P. While the car is in the workshop having the head gasket repaired now is the time to do it but do you guys have any experience of these sellers or can recommend anyone?
Just interested as I am always waiting for this in cold weather.
Probably second most common problem after HGF
Replied by David Aiketgate on topic Broken rear window replacement
Posted 9 years 11 months ago #155362David
All Panels are supplied with the necessary long, black powder coated rivets and CD Video showing the fitting procedure. Watch me fit one in 15 minutes:
- adamelphick
Looking at the photo of your cracked screen you do seem to be missing the 'parcel' shelf cover (hood well). I've dispensed with the massive sound deadening as I got fed-up fighting it everytime I wanted to remove the engine cover but I have peeled off the top layer to use as a liner as it cushions the blow a bit when the hood is lowered which is quite important if you go 'glass'.
Richard
- ashleyfrazer
- Apprentice MGer
Replied by ashleyfrazer on topic Re:Broken rear window replacement
Posted 9 years 11 months ago #155375Please Log in or Create an account to join the conversation.
ashleyfrazer wrote: You need the relay for the fuse box under the steering wheel and a switch for the dash. The wiring was fitted at the factory. Dig under the parcel shelf carpet on the passenger side. Ash
I think MGFMania can supply a relay & switch...cars that have had a hard top tend to have them fitted already so check first!
R
