Rear Trailing arm bushes
Rear Trailing arm bushes was created by Rog-tf
Posted 9 years 9 months ago #156959
Hi all,
I had a knocking sound from the rear off side suspension.
I have found that the lower bush in the trailing/radius arm where it attaches to the hub is shot.
Is it possible to re-bush these or is it a matter of replacing the whole arm?
Thanks
by Rog-tf
Replied by Denial on topic Rear Trailing arm bushes
Posted 9 years 9 months ago #156960
Hiya,
assuming you can get the arm off you should only need to replace just the bushes, similar post below maybe of some help. I believe the general consensus is that you should do both sides at the same time. Hope that helps, if not, i'm sure it won't be long before someone more knowledgeable than me comes along.
http://www.the-t-bar.com/forum/9-mgf-tf-pitstop/87880-rear-trailing-arm-bushes
by Denial
The following user(s) said Thank You: Rog-tf
Replied by Rog-tf on topic Rear Trailing arm bushes
Posted 9 years 9 months ago #156962
Thanks, but the link is for MGF bushes that are different.
by Rog-tf
Replied by john and Jake the dog on topic Rear Trailing arm bushes
Posted 9 years 9 months ago #156964
Hi, having just had my rear hubs off , I can say that the bolts through the two bushes are some of the easiest to remove. But watch when putting them back in. They are tricky to line up. I crossed the threads and had to clean them back up with a die.
Don't know about bolt 4 as I didn't go that far.
Replied by David Aiketgate on topic Rear Trailing arm bushes
Posted 9 years 9 months ago #156981
http://www.rimmerbros.co.uk/Item--i-RP1047TF
Although I don't know whether those bushes are included.
Replied by Terrible on topic Rear Trailing arm bushes
Posted 9 years 9 months ago #156989
Hello
I haven't seen that specific bush listed by MG ROVER or any of the Poly companies.
But I would think a poly company would do a generic one if you know the dimensions.
Time to create page: 0.544 seconds
