tf clock replacement
Hi guys! 54plate mgtf
HELP, the clock is broken and needs replacing! air vent out, but does the clock unscrew or pull, i can turn it round (both ways) but dosent remove....
Regards Ade
by shady
- Andy Lawrence
Welcome to the forum.
You'll find its held in place by a circular plastic ring screwed to the centre console.
You need to remove the centre consol to change it.
Whilst you've got them out it looks better if you swap them round so the clock is nearer the passenger.
WHALE OIL BEEF HOOKED
As above there is a securing black plastic bracket that holds both the clock and oil temp gauge in position. That is held in with small screws to the back of the centre console.
Time to create page: 0.775 seconds
