Another flat battery...
My clock seemed to be stopped when I got in the car but worked ok most of the time, then the battery was flat yesterday, wouldn't charge off my charger as it was shorted in the battery.
Don't seem to have much look with batteries replaced mine last year after it would not start, then starter motor went.
Replaced starter and it would occasionally not turn over, charge battery and it would start. found out the starter was duff.
Changed starter all seemed ok then battery has just gone! ARRRGGHHHH!
Fitted a volt meter last year so I can seem whats going on.
My led interior lights glow slightly when doors closed also.
Is it a difficult job taking out the boot loom, having similar problemsmudger69 wrote: Touch wood, I had the boot loom out last week and fund a wire with split insulation, although it was already taped up, I wrapped more tape round it and I haven't had a flat since, just a smashed rear end instead. Insurance sorting that..
- mgtfbluestreak
cojohill wrote: Is it a difficult job taking out the boot loom, having similar problem
Not that bad, you can reach all the plugs on the inside. Make sure you attach a draw cord as you pull it out so you can pull it all back again.
bryan young wrote: Boot loom/hinge wiring and the earth connection between the gearbox and bulkhead, bad connections here can cause rapid battery drain.
I fitted a second alternator and it failed within a week. I then got a top of the range alternator and - touch wood - it's been perfect ever since.
MarkL wrote:
Hi and welcome to the forum Mark.
James
