Inlet manifold jiggle valve.
  • mgtftone
  • 2003 MGTF VVC
Inlet manifold jiggle valve. was created by mgtftone
Posted 8 years 9 months ago #164605
:dry: Hello to all MGF/TF fans hope you are all well. First time on here and wandering if someone may help me. Looking forward to chatting with you and not always with problems.
Following a HGF repair on my MGTF VVC 160 I was told by the mechanic that he had removed the inlet manifold jiggle valve. When asked why, he said that is what they do????
2000 miles on the car is running ok. I have noticed that the temp gauge goes to normal after about 1 mile, though the heater does not get warm until 3 miles. Once hot the heater stays hot (while set to hot) with no fluctuations. This situation is always the same on start of a run. I bled the coolant system several times at the three points I am aware of.
I had read this situation may because the jiggle valve has been removed!!!
Can anyone please advise me if I can refit the valve, or get an inline one. Or have I got another issue.
Last Edit:8 years 9 months ago by mgtftone
Last edit: 8 years 9 months ago by mgtftone. Reason: clarity
Replied by cairnsys on topic Inlet manifold jiggle valve.
Posted 8 years 9 months ago #164606
:welcome: :welcome: :welcome:
Can't really help you with the jiggle valve question but someone will come along who will I'm sure.
Replied by David Aiketgate on topic Inlet manifold jiggle valve.
Posted 8 years 9 months ago #164607
:welcome2:
I wouldn't worry, it all sounds pretty normal, heating wise.
The jiggle valve is to allow only air to escape from the head waterways then close to stop water exiting the small pipe. This valve can sometimes become blocked and so air can hang around the head.(not good) Removing the ball from the valve just prevents this problem from raising its ugly head. I wouldn't expect any problems
( or noticeable difference) with it removed.
Last Edit:8 years 9 months ago by David Aiketgate
Last edit: 8 years 9 months ago by David Aiketgate.
The following user(s) said Thank You: cairnsys, Fisher
Replied by mgtfbluestreak on topic Inlet manifold jiggle valve.
Posted 8 years 9 months ago #164612
Last Edit:8 years 9 months ago by mgtfbluestreak
Last edit: 8 years 9 months ago by mgtfbluestreak.
The following user(s) said Thank You: mgtftone
Replied by talkingcars on topic Inlet manifold jiggle valve.
Posted 8 years 9 months ago #164623
Hi and welcome to the forum
  • mgtftone
  • 2003 MGTF VVC
Replied by mgtftone on topic Inlet manifold jiggle valve.
Posted 8 years 9 months ago #164628
Thank you for your greetings and comments. Hope all is well
Regards Tony :wave:
  • mgtftone
  • 2003 MGTF VVC
Posted 8 years 9 months ago #164629
Thanks for your greetings Robin. and your comment. I am sure I will be sorted.
  • mgtftone
  • 2003 MGTF VVC
Posted 8 years 9 months ago #164630
Hello David. Thank you for your greeting. I appreciate your comments and information, you have put my mind at rest. Hope all is well with you.
  • mgtftone
  • 2003 MGTF VVC
Posted 8 years 9 months ago #164631
MMMMM :oops: Red face here. Sorry I am trying to reply to you all individually thanking you for your kind greetings :woohoo: and information/advice. Sadly I am still getting to grips with the forum, hey ho will master it. Can not be as difficult as trying to work out as to what happens on a MG TF. :nonod:
Regards (will try harder) Tony.
Replied by Raccoon on topic Inlet manifold jiggle valve.
Posted 8 years 9 months ago #164632
Keep on trying Tony! ;)
Welcome aboard!
by Raccoon
Replied by mowog73 on topic Inlet manifold jiggle valve.
Posted 8 years 9 months ago #164634
Hi Tony,
Both of our MGFs have had the ball in the jiggle valve removed by a previous owner and the cars both seem to operate well.
[size=10pt]Mark[/size]
95 MGF
by mowog73
The following user(s) said Thank You: Fisher, mgtftone
  • mgtftone
  • 2003 MGTF VVC
Posted 8 years 9 months ago #164635
Hello Mark. Nice looking car!
Thank you for your reply. It would appear I am worrying unnecessarily. But after the HGF I have become twitchy.
Do your MGF's takes three miles for the heater to warm to?
Regards Tony.
Last edit: 8 years 9 months ago by mgtftone. Reason: After thought
Time to create page: 0.541 seconds
