Handling and steering
My motorcycle is now a single seater for the same reason!
Hope you enjoy the Eos. Roll on the summer and some sunshine.
Winko
Toyo proxes are fine provided they are Japanese all round or Malaysian all round - mix the 2 up in anyway and it's horrible!
NOT TRUE from tyres made from 2014
What's not true? Are you saying that you can mix Japanese & Malaysian made tyres?
I have had a wee look on the net about the Toyo's and there are some conflicting reports some folk have said they have mixed the Toyo's with old and new and found they are fine where as others have said the car was undriveable. Toyo's official line is that you should not fit old on the front and new on the back. If you do end up with a mix of Toyo's they say the best way to do it is have the new on the front and the old on the rear as this will be less noticeable. If it were me i think i would avoid it and get a matching set rather than having the mix.
http://www.vehiclehandlingsolutions.com/products.htm
Thanks
Alan
When I got 4 new T1Rs 2 were Japanese and the other 2 Malaysian but the same compound is used in both after 2014Blow-in wrote:
Thanks for the clarification. The advice from the MGOC is that the Japanese spec changed in September 2014 to match the Malaysian spec and that mixing the specs is not a good idea. So Malaysian allround, no problem (spec was not changed), Japanese allround all from before September 2014, no problem too or indeed allround from after September 2014 no problem either. The problem comes mixing Malayasian tyres with pre- September 2014 Japanese ones or indeed mixing pre-September 2014 Japanese tyres with post September 2014 Japanese tyres.
Richard
Richard
- mgtfbluestreak
- mgtfbluestreak
I've now got to the bottom of the problem...
1. My expensive but old tyre pressure gauge is now in the bin! Using a professional set up, I found that whilst I had 26 in the fronts ok, the rears were 30 and 32 v. the 36 everyone recommended.
2. The 2 o/s engine mounting bolts were loose. Looks like the garage that did Roxy's timing belts last year didn't torque them up and they'd worked loose enough for the engine mounting to drop 30-35mm or so. It wasn't till I gave her engine bay a really good clean and shone a powerful lamp at the mounting that the gap could be seen. (Old eyes are no fun!)
Anyway, with tyre pressures correct and the engine mounts firmly torqued, I now have a completely transformed car.
Thank you again everyone....
- richandpaula
We also have an 04 135 Sunstorm in Nightfire. Welcome to the T-Bar!
