TF Play in new rear bottom shock absorber bush
- BruceTF135
TF Play in new rear bottom shock absorber bush was created by BruceTF135
Posted 8 years 6 months ago #167625I have an advisory for play in the lower bush on the right-hand rear shock absorber. I've bought new shocks and bolts but the fit is terrible. The bush is about 13mm in diameter but the bolt is less than 12mm in diameter. That is 1mm or more of free play.
I know that this will all be done up tight but won't it tend to work loose and move about once the car starts going over bumps? I would have expected the bolt to be a snug fit in the bush. My local mechanic agrees with me.
I spoke to the supplier of the bolt and shock absorber and they say that this play is normal.
Is it? Am I worrying unnecessarily? Or does it need packing out in some way?
Please can anyone help or advise?
Replied by David Aiketgate on topic TF Play in new rear bottom shock absorber bush
Posted 8 years 6 months ago #167664Having said that, I would not be surprised by a mismatch on the TF as the F suffers from an inner sleeve several mm too long allowing the bottom of the damper to move around! :bang:
(nb) I've just checked and you can now get replacement poly bushes for the TF damper bottom bush Part No.: RNF100090LPB Then it would be a case of obtaining a properly sized steel sleeve.
- BruceTF135
Replied by BruceTF135 on topic TF Play in new rear bottom shock absorber bush
Posted 8 years 6 months ago #167672I looked at the polybushes you mention and the item description is ambiguous. At the top of the description, it says Kit 13 is for the top. Further down, it says "Set of 8 bushes (upper & lower for the front shock absorbers)". Then "Air suspension vehicles". Then, at the bottom, there are diagrams showing the bushes fitted to top and bottom of both front and rear dampers.
I phoned Rimmer and they said that they are for the top and that the bottom bushes are not replaceable.
I just found this which sounds familiar if not exactly the same.
I'm confused!
- Gerry.laing
Replied by Gerry.laing on topic TF Play in new rear bottom shock absorber bush
Posted 8 years 6 months ago #167676thought the same when I purchased the VHS suspension kit and new bolts, but the bottom collar of the shock fits into a recess in the bracket so the bolt has no load on it once tightened,
Gerry
Posted 8 years 6 months ago #167677David
Posted 8 years 6 months ago #167678David
- BruceTF135
Posted 8 years 6 months ago #167696Yes, I saw that too. It seems clear enough - shock absorber bush kit, lower. But if you drill down into the link, the description says it's something else.
Confusing, as you say. that's why I phoned them.
Thanks,
Bruce.
- BruceTF135
Posted 8 years 6 months ago #167697Gerry.laing wrote: Hi Bruce,
Gerry
Ahh! That's very interesting. Thanks, Gerry, I'll report back when it's done.
Cheers,
Bruce.
- BruceTF135
Posted 8 years 5 months ago #169152It's worth noting that the old bolt had exactly the same amount of play in the old suspension unit as in the new parts. It seems that this free movement is completely normal. Once fully assembled, nothing moves about!
