MGR Chrome rollbars
Daughters TF115 arrived today and is fitted with Chrome roll hoops. I believe these are MGR and can just see a hologram on the base.
There is no wind deflector, can a normal one be fitted?
This is the third TF to arrive,, I've been recommended to see a shrink or seek medical advice for a mid life crisis :dry:
by Ian S
The following user(s) said Thank You: Hammy
- Andy Lawrence
Post a pic,
Some that fit through the t-bar have their own deflector inserts,
ones that fit behind the t-bar will accept a standard deflector but won't let you fit a glass screen hood.
Collecting mg's is a way of life I'm afraid. :broon:
WHALE OIL BEEF HOOKED
- SundanceUK
I fitted one of the perspex type to mine just in front of the roll hoops. I did have to make 3 L shaped brackets to mount it that fix underneath the tonneau studs and also had to drill two holes in the deflector (the middle hole was good to use).THe deflector now sits snug in front of the hoops....
.....Sundance
.....Sundance
Last Edit:8 years 3 weeks ago
by SundanceUK
Last edit: 8 years 3 weeks ago by David Aiketgate.
by Bob
Last edit: 8 years 3 weeks ago by Bob.
Perfect Same roll bars. I was a bit concerned about the angle that the hoops lean and whether that would prevent fitting
Many thanks -one less item to sort
by Ian S
Time to create page: 0.472 seconds
