Oil Gauge Light gone !! Help!!
Oil Gauge Light gone !! Help!! was created by leemans
Posted 14 years 9 months ago #9455
Ok Guys
Need to replace the oil gauge bulb!! :dunno:
I took out the central air vent to gain access!!
But can't seem to get any further!! :confused:
Is this a sealed unit ? or how do i get to replace the bulb!!
Just seems like 2 connectors to the back of the gauge!!
All help/suggestions appreciated!!
Lee
by leemans
Replied by rough luck on topic Oil Gauge Light gone !! Help!!
Posted 14 years 9 months ago #9458
Hi
Remove your gear stick surround and pull out your centre dash, radio maybe out an heater dials off. The bulb is on the top of the dial, it depends how old it is but can be either a twist and pull bulb holder or just a striaght pull out holder
It doesn't take to long though
Good luck
Replied by Adam-Mgtf on topic Oil Gauge Light gone !! Help!!
Posted 14 years 9 months ago #9472
Rough Luck;9458 wrote: Hi
Good luck
isn't that for the heater bulbs mate?
for the oil temp gauge then it's a sealed unit with 2 surface mount L.E.Ds inside... you need to:
Remove the gear knob
Remove gearstick gaiter
Remove your CD player (not necessary but recommended)
Remove the Center console and unclip the switches etc
unscrew the 4 screws at the top of the console and that gets you the oil temp gauge out the car
now you need to open the gauge up (its about a 6 step process) then de-solder the original surface mount LEDs and solder on new ones you can get them from maplin for pennies
this site should help you out massively... it's he guide i used to replace mine with red ones :)
http://www.mgf-tf-central.co.uk/iainross/gauges.html
It's a tricky job as far as soldering is concerned but if you find someone who knows what there doing you should be ok (hint: tweezers and a steady hand are your friend lol)
anyway, hope that helps :)
Posted 14 years 9 months ago #9486
OOoo those pics are different to both of mine
my early one just had a push in steel tube arrangement
then I changed the dials to silver an that had a twist an pull holder
so by the sounds of it ..its the same process but with 3 possible bulbs
Replied by leemans on topic Oil Gauge Light gone !! Help!!
Posted 14 years 9 months ago #9492
Thanks guys!!
Will take another look ASAP!!!!
Many Thanks for your help/suggestions!!!
Lee
by leemans
Posted 14 years 9 months ago #9516
Cool mate, let us know how you get on... And if the f is different to the tf... I'm guessing it is??
Replied by swerving on topic Oil Gauge Light gone !! Help!!
Posted 14 years 9 months ago #9538
Lee, I did mine late last year.... As far as I remember the vent removal way is the way to do it. I did also have the radio out at the same time, so that have made it easier.
Mine was just as Rough Luck describes but you need girly sized fingers!
Peter
Older but certainly not wiser!
Replied by David Aiketgate on topic Oil Gauge Light gone !! Help!!
Posted 14 years 9 months ago #9543
My mk2 F has the simple push in bulb like Jon (Rough Luck).:yesnod:
Time to create page: 0.545 seconds
