Low Coolant Level Sensor
Did you start the engine before turning the tank upside down to activate the reed switch?
It will take about 30 secs before the light will activate.
Shine a torch under the dash behind the speedo, if there is no bulb you may get light showing through the hole.
Bridge the contacts in the plug to simulate activation of the sensor.
Popping the speedo out is only undoing a few screws.
The next question is....what are the few screws that need undoing?
I'm sure I am not the only person who appreciates this How To.
Bob
So all I need to do now is swap the bottles over and I am sorted. Can stop worrying about damaging the engine if I get a coolant leak.
Thank-you for your help.
I have found this mystery plug on my TF, does anyone know if it is the Low Coolant Sensor connection mentioned in the thread?
If it is a TF there should be a valve on the O/S tail pipe to open and close the tail pipe, I suspect this plug is for the control unit for the valve.
Only late TF had the low level alarm wiring.
