Headlamp query
talkingcars wrote: Are you sure the bulbs aren't up side down?
Easy to do or so I'm told. Of course I haven't done that :whistle:
Robin
Neither have I, nor have I not seated them correctly & not noticed till MOT time
![:) :)](/media/kunena/emoticons/8.png)
Pre- 2000/2001 Fs had poor silvering/chrome on the reflectors that deteriorated with time and heat.
Check the dipped beam against a wall or similar. If there is no distinct cut off line at the top of the beam, then it's probably the reflectors.
Unfortunately the only answer is to rechrome them or replace with later headlamps. Neither option is a cheap fix!
There are a lot of non "e" marked bulbs on the various auction sites that claim they are Xenon or similar but when installed the beam pattern is useless.
Guess how I found out!
- BruceTF135
Never again, anyway!
I have a feeling the reflectors are not as good as they look.
Anyone got a good set of headlamps for sale which will pass an mot?!!
Beginning to fear the worst that I need new headlamps ????
The guys are correct, the headlights suffered from a dulling of the silver finish caused by the heat of the bulbs.
There is a company in the midlands, Duel Metallising, who will resilver your reflectors for around £100.00 a pair, but you will need to disassemble the units. Give them a call.
If you have this done, refit xenon bulbs as these run a lot cooler than the standard bulbs. These will help prolong the life of the units.
Cheers
But have a look about for places that do metalising. My bloke's main business is making metal lookalike plastic coffin hardware for the funeral trade.
You maybe lucky enough to find someone like my bloke, who'll do it at a reasonable price.
Once you have your shiny new remetalised coating on your reflectors, treat yourself to some Osram Night Breaker bulbs, these really do improve lighting your way over standard bulbs.
