Coolant temp. gauge not working
Replied by David Aiketgate on topic Coolant temp. gauge not working
Posted 7 years 6 months ago #178017David
Posted 7 years 6 months ago #178022:nonod:COMMANDER wrote: Photo.
Posted 7 years 6 months ago #178025You can use a fine screwdriver to depress this tab, and the pin will push back out of the plug.
Solder on a new piece of wire and push the pin back in until it clicks into place
I crimped bullet connectors onto the original wire and the end of the new tail.
Be careful the plastic plug internals don't break up, mine did.
but it will need a proper insulated terminal at some point.
IIRC these plugs are made by Ford, have a look at https://www.simtekuk.co.uk/ for a replacement.
