Fitting Parking Sensors - MGTF
Fitting Parking Sensors - MGTF was created by Fisher
Posted 7 years 3 months ago #180924
Hi All
Just purchased a set of parking sensors to be fitted to my 2004 TF . I have read all the past posts on fitting these kits, but not have found any post with definite location dimensions for the 4 sensors.
If one of you guys have fitted the rear 4 kit sensors, can you please supply the dimensions you used to cut the holes. Taking them from a common point on the bumper.
I am OK with the height of the sensors which I plan to mount at approx. 500mm from floor levek
I do not wish to hit anything that may be lurking behind the bumper!
Regards and thanks in advance.
Robert
by Fisher
Replied by SundanceUK on topic Fitting Parking Sensors - MGTF
Posted 7 years 3 months ago #180928
Not got exact dimensions, but here is a shot of my rear bumper with the parking sensors fitted.
It may help to give you some idea where you could put them.
They do work well and and I looked at many pictures of sensors in TF's to try and work out the best position for them.
I took my bumper off to fit them and ended up opening up a can of worms.
Had to replace the upper brackets that fit the top of the bumper into the boot and had to replace the crash cans as these were rotted away.
It also gave me a chance to treat some rust on the rear panel behind the bumper and I also fitted a reversing camera which is linked into my ICE head unit.
The camera is superb and even works in low light, enhancing the rear view in the dark.
Hope this helps...
Sundance
Parking sensors
Rear panel refurbs
Reversing camera
The following user(s) said Thank You: Fisher, therobster
Replied by Fisher on topic Fitting Parking Sensors - MGTF
Posted 7 years 3 months ago #180930
Sundance thank you, that was what I was looking for. I will use the photos body lines as datum points. Great!
Regards
Robert
by Fisher
Replied by mgtfbluestreak on topic Fitting Parking Sensors - MGTF
Posted 7 years 3 months ago #180932
Can't see the need for them on such a small car that the f/tf is...
Last Edit:7 years 3 months ago by mgtfbluestreak
Last edit: 7 years 3 months ago by mgtfbluestreak.
Replied by talkingcars on topic Fitting Parking Sensors - MGTF
Posted 7 years 3 months ago #180940
mgtfbluestreak wrote: Can't see the need for them on such a small car that the f/tf is...
Rear visibility, especially with a glass rear screen in the soft top, is not brilliant.
Also it helps in tight spots like the one I park in.
Posted 7 years 3 months ago #180941
I'm not sure about the F/TF but some modern MG/Rovers have marks on the inside of the rear bumper to guide you.
Posted 7 years 3 months ago #180943
I concur with Mr TC the glass screen reduces your peripheral rear vision, although its a lot clearer than the plastic screen.
Throw in roll hoops and a tinted windstop and the rear window is only good for checking what's driving behind you on the road and is no good for when backing up into tight places.
I really think the reversing sensors are one of the best things I have put on the car, and if they stop me hitting another vehicle or even a person, they are worth the trouble....and at 15 quid a set, its a no brainer for me - and they are so easy to fit!
The camera is good to as it gives me a clearer view in dimly lit areas, like night vision, but I would say the sensors are the better of the two.
I also put some in Mrs Sundance's car, a Renault Wind which has little rear vision, after she backed into my TF and damaged my front bumper....a £100 repair at the bodyshop!
Anything that can reduce risk surely must be a good idea!
Sundance
Last Edit:7 years 3 months ago by SundanceUK
Last edit: 7 years 3 months ago by SundanceUK. Reason: addidtional text
Posted 7 years 3 months ago #180948
I'm not against sensors..I've got them on another motor..handy because that car is a supermarket space filler..I suppose I've got used to driving my van..with internal bulkhead,no rear windows or rear view mirror..just use door mirrors. ..has for the tf..plastic screen..no windstop no hoops or spoiler...just got to watch Mrs Sundance don't back into it....
The following user(s) said Thank You: SundanceUK
Posted 7 years 3 months ago #180974
I'm spoilt on the mazda with the audible visual display..
So getting in the tf..it's nice to have the simplicity of using mirrors..
Posted 7 years 3 months ago #180981
Bloody hell Bluestreak, you grown hair....mmmm and is there summat else you aint told us?
Lol
Sundance
Posted 7 years 3 months ago #180988
Yes I've saved up and lashed out on the Sophie ellis bextor look....I still can't dance though...it's murder on the dance floor. :P
Replied by BruceTF135 on topic Fitting Parking Sensors - MGTF
Posted 7 years 3 months ago #180994
I'm also thinking of fitting rear parking sensors to my TF. I find it really hard seeing out the back. You are sitting really low and I'm not as flexible as I once was, to turn right around. My daily drive is a LWB Mercedes Vito van and it's easier to park because the mirrors are huge compared with the silly things on the TF.
TC is right about marks inside the bumper. Dunno about the MG but my Vito has them (haven't fitted sensors to it though).
Time to create page: 0.504 seconds
