Fitting Parking Sensors - MGTF
Replied by mgtfbluestreak on topic Fitting Parking Sensors - MGTF
Posted 7 years 1 month ago #180997
ok i havent any hair.....id better come clean and show the real image in my little tf mirror....
Last Edit:7 years 1 month ago by mgtfbluestreak
Last edit: 7 years 1 month ago by mgtfbluestreak.
Replied by SundanceUK on topic Fitting Parking Sensors - MGTF
Posted 7 years 1 month ago #180998
Now that's the Bluestreak I remember!
Sundance
Replied by talkingcars on topic Fitting Parking Sensors - MGTF
Posted 7 years 1 month ago #181006
BruceTF135 wrote: .....My daily drive is a LWB Mercedes Vito van and it's easier to park because the mirrors are huge compared with the silly things on the TF.
Same with my Volvo FM10, rear is some 9 metres back, no reverse sensor and a screen for the reverse camera that goes up and down with no logic and gives no picture.
Replied by therobster on topic Fitting Parking Sensors - MGTF
Posted 6 years 9 months ago #183596
Following your excellent post I fitted sensors today, removed the bumper as detailed, quite easy really, drilled the holes and then drilled 2 holes to feed the cables through a grommet, left the number plate ones where they were. All the cables now in the boot, I know where the live for reverse is, the green and brown wire but where did you wire the earth ? Just need to wire them up now and feed the cable for the speaker into the cabin
Posted 6 years 9 months ago #183601
therobster wrote: Following your excellent post I fitted sensors today, removed the bumper as detailed, quite easy really, drilled the holes and then drilled 2 holes to feed the cables through a grommet, left the number plate ones where they were. All the cables now in the boot, I know where the live for reverse is, the green and brown wire but where did you wire the earth ? Just need to wire them up now and feed the cable for the speaker into the cabin
I am sure there is a earth stud in the rear compartment behind the boot liner on the left hand side if I remember - near the top. There is a major earth stud in the engine bay on the left also, look to the side of the fuel filter.
Sundance
The following user(s) said Thank You: therobster
Replied by Airportable on topic Fitting Parking Sensors - MGTF
Posted 6 years 9 months ago #183604
If you're picking up the positive from the light cluster, pick up the ground up also.
Replied by John and Sue on topic Fitting Parking Sensors - MGTF
Posted 6 years 9 months ago #183609
Reversing sensors on an MG.... Hmmm. Really?
You may also need them on on a Smart Car, with marginally less overhang than an MG.
Last Edit:6 years 9 months ago by John and Sue
Last edit: 6 years 9 months ago by John and Sue.
Posted 6 years 9 months ago #183611
mgtfbluestreak wrote: ok i havent any hair.....id better come clean and show the real image in my little tf mirror....
I know the Mods don't like us quoting pics, but you appear to be in the passenger seat here.....
You have also stolen my image.....
Posted 6 years 9 months ago #183628
Many thanks, it's a lovely day so will get on that today 😊
Posted 6 years 9 months ago #183633
Having replaced the plastic screened hood for glass, I found the rear view restricted & reversed into a low stump, which would have been visible before. That cost me a fresh bumper, so for under a tenner I fitted the sounder only kit. Scoff if you will but buy by the time I had the bumper painted I was £150 down. I don't want that again.
I fitted 3.5mm jacks on the sensors & sockets through the rear panel, adjacent to the sensors, that allows for easy bumper removal, plus you can dress the cables to length, so you don't end up with a boot full of wire.
Replied by NikTheGeek on topic Fitting Parking Sensors - MGTF
Posted 6 years 9 months ago #183653
I've retro fitted them to the rear of the MG and to the front and rear of my 4x4. I have to get 3 cars on the drive so every inch counts :)
Posted 6 years 9 months ago #183666
Git them wired up and tested, and working, can you tell me how you managed to feed the cable into the cabin, I cannot seem to find anywhere that I can get the monitor cable through
Time to create page: 0.550 seconds
