Back End Gone Very Loose
Replied by David Aiketgate on topic Back End Gone Very Loose
Posted 7 years 1 month ago #181321
https://www.the-t-bar.com/forum/21-david-aiketgate-s-guides/88966-compliance-washers-what-s-that-about-then#179738
Replied by cairnsys on topic Back End Gone Very Loose
Posted 7 years 1 month ago #181322
David Aiketgate wrote: Another possibility is the compliance bushes have given up the ghost this can result in a rear wheel steering effect, which is very disconcerting.it would feel like your description..
The compliance bushes are located in the middle of the rear bottom arms. They are large bushes that locate a rod that comes from the front of the subframe.! It is possible to add shims/ washers to take up the slack. I have a 'how to' if you look In the list
The compliance bushes 'looked' OK to my eyes but will check again once Storm Brian passes over later in the weekend. They were certainly nothing like the ones in the pics in your How To, with no visible gaps at all. Will take some photos when I get a chance.
Another thought - suspension spheres? The ride is possibly a little low at about 350mm but hasn't changed since the last time I measured it a couple of months ago.
Last Edit:7 years 1 month ago by cairnsys
Last edit: 7 years 1 month ago by cairnsys.
Posted 7 years 1 month ago #181323
BruceTF135 wrote: When is the MOT due? If it's anytime soon, it might be worth popping it in early. I'd have thought that an MOT tester would have noticed something as bad as you describe. I can only think of things you've already looked at, i.e. flat tyre, loose wheel nuts etc.
Sounds horrible!
MOT not due till January but I may be seeking professional help with this one!
Replied by Steve on topic Re:RE: Back End Gone Very Loose
Posted 7 years 1 month ago #181327
cairnsys wrote:
graham1 wrote: sounds to me like your rear shocks need looking at, soft shocks are like driving on ice,
Thanks Graham. I did the bounce test and all seems solid enough on the shocks aspect. Also, this has happened very suddenly, not a gradual thing at all. As I said, I'd been cornering fairly vigorously (for me anyway) a few miles previously and it was handling like a dream, so it feels to me like something has failed very quickly.
I am wondering whether it could be a diff problem but forgot to check for that this morning. Is it possible for the diff to lock for any reason. I did notice an oil leak from the inner drive shaft area.
Possibly a bush gone soft maybe
Sent from my SM-J500FN using Tapatalk
by Steve
Replied by g4wam on topic Back End Gone Very Loose
Posted 7 years 1 month ago #181329
Hi there,
my thoughts.are that if it was an MGTF it would be caused by the appropriate side rear lower arm link bush at the hub end-it happened to me this year very frightening behavior at low speed on a wet surface
Just looked at the EPC (.https://www.the-t-bar.com/axles-suspension-drive-shafts-wheels/23-rear-suspension/333-rear-lower-arm-mgf ) on this web site and the F has the same style lower arm.
You could check for bush wear by suspending each rear wheel after jacking up and try to rock the wheel side to side
Mike
by g4wam
Posted 7 years 1 month ago #181330
g4wam wrote: Hi there,
Mike
Thanks Mike. I have checked for side to side movement and felt a little on the LH rear which was due to the hub nut slackening off every so slightly I think. I couldn't feel any other movement. Just to be clear on the part you refer to, which number is it on the EPC? I think it may be the compliance washers that David refers to above but just to be sure.
Posted 7 years 1 month ago #181342
Also check the inner bush and outer ball joint on the rear track control arm.
Posted 7 years 1 month ago #181343
Movement may be wheel bearing on the way out.
Posted 7 years 1 month ago #181348
Part 21 on the diagream
by g4wam
Replied by mowog73 on topic Back End Gone Very Loose
Posted 7 years 1 month ago #181351
I found nut #10 missing on my car one time when handling went wonky.
[size=10pt]Mark[/size]
95 MGF
by mowog73
Posted 7 years 1 month ago #181352
g4wam wrote: Part 21 on the diagream
Great - thank you. Not the one I was thinking of. I will check that as well. David also suggested that component as worth checking.
Replied by G0RSQ on topic Back End Gone Very Loose
Posted 7 years 1 month ago #181359
cairnsys wrote: Thanks Mike. I have checked for side to side movement and felt a little on the LH rear which was due to the hub nut slackening off every so slightly I think. .
Those nuts don't just come loose!
Either the hub has failed or the bearing needs replacing as previously advised.
by G0RSQ
Time to create page: 0.631 seconds
