boot release cable
Mike
The solenoid system requires a single wire from a 12v source & if you use a lock motor off e-bugger for less than £4-00; a couple of holes will fit that to the lock bracket. And why worry about “electrickery”, without it you’re going to be sat on your drive for a very long time.
Just one point to add -dont keep two fobs close together or they will corrupt the SCU coding
Mike
Plastic bag and cable tie, That's what I usegraham1 wrote: never thought of that, thanks, I will buy a magnetic box and hide it under the body somewhere. saves me a lot of hassle, thank you.
Sent from my SM-J500FN using Tapatalk
At some point I plan to hid a reed switch somewhere on the car so I can pass a magnet over it to release the boot solenoid, taking it a step further on could have a 6mm jack socket on the underside of the car somewhere so I can apply a charge to the boot solenoid to get over a flat battery.
- mgtfbluestreak
