timing belt change
- The driving dutchman
Then he slides on the new belt over the free half of the wheels. At last he cuts through the remaining half of the old belt to slide the new one further on its place and done!
Has anyone done it like this?
Verstuurd vanaf mijn SM-G920F met Tapatalk
I swore never more to touch the timing belt anymore.
Regards
Christof
- mgtfbluestreak
This is in turn gives you a little more work. .has the water system has to be drained and bled accordingly when refilled...the alternator tentioner is often siezed so replacing this with a modied system is about another £25...but I drilled my siezed tensioner pin out and replaced it for a metric 8 pin...glad I did the job myself..has I went through everything including checking the crank dampener ..ther rubber insert on the crank pulley..sometimes you can see these bonded centre rubbers oozing out..eventually the crank pulley becomes 2 parts has it disintegrates...mine was in good nick so the total cost of doing the job shaved a lot off your quote.. the 160bhp has another belt for the vvc mechanism..I used gates belts because they are good quality.
- mgtfbluestreak
- mgtfbluestreak
- mgtfbluestreak
- mgtfbluestreak
Above the 2 locking tools I used for the job...advertised on ebay are 2 types of locking tool for the flywheel..they are for 2 types of gearbox..the pg1 and the pg2...the tool for the pg2 has more holes and does both models
