timing belt change
Replied by mgtfbluestreak on topic timing belt change
Posted 7 years 3 weeks ago #181728
They are for sale now and again on ebay...but new prices may slap you a bit..mines a britool..have seen one for around £100..that's for a used second hand one....if you were to buy a new one..I've seen simular at £300
Last Edit:7 years 3 weeks ago by mgtfbluestreak
Last edit: 7 years 3 weeks ago by mgtfbluestreak.
Posted 7 years 3 weeks ago #181729
Ah yes just had a look on ebay..different qualities and different specs...I think the norbar one is closer to mine.
Mines a britool..wouldn't of liked to buy it new..Helped take some wheels off a crane about 25 years ago and we used a very large power bar with a scaffold tube attached..after both of us did monkey impressions bouncing on the bar with no effect to the wheel nuts ..............the guy I was working with produced the multiplier from his toolbox....we cracked the wheel nuts off quickly using the tool...I was that impressed.I had to get one.
Replied by G0RSQ on topic timing belt change
Posted 7 years 3 weeks ago #181730
These are what I use at work.
The smaller ones, at about 8,000 Nm
You do not want to know the price :omg:
IBT Torque wrench
For the big bolts, we use pneumatic torque wrenches, which require a crane to hold them in place
by G0RSQ
Posted 7 years 3 weeks ago #181732
Wow 8000nm that's some serious power innit...that should blow the bolts off the tf engine mount...different world out there working with that gear...makes our tools look like something from toys r us
Replied by graham1 on topic timing belt change
Posted 7 years 3 weeks ago #181733
sorry for that price I will use my brute force, or pay too have the lot done at once, but thank you for looking into this for me.
by graham1
Posted 7 years 3 weeks ago #181734
You should be OK. .using a good power bar..I only got a multiplier because of the engines I was building had a high angle torque setting after torque down....building at least 1 engine every 2 weeks with a bit of strain injury to my joints got me thinking about reducing the strain to my ever aging body.....well I say tough bolts...but gorsq has just knocked the thought of these bolts being hard to tighten out of the window with his job...like to see some pics of that work environment. ..
Heres a pic of the engine I've just built a multiplier can make the job easier..
Oh no have I hijacked this threaìd again...
Iast time I had the engine cover off on my mgtf I stripped a couple of threads ...the little m6 pins were slack in a couple of holes.so when I take the cover off to check the engine mount..I will put a couple of helicoils in ......
Posted 7 years 3 weeks ago #181736
I'd never seen the auto tentioner before and looking at it through a mirror was strange at first ...I went through the procedure 3 or 4 times just to get the feel...good idea.
Replied by talkingcars on topic timing belt change
Posted 7 years 3 weeks ago #181738
Blue streak - can you get the auction numbers for those?
Posted 7 years 3 weeks ago #181739
Yes using my phone because I'm out at moment and for some reason it only shows item number for the norbar 162727681802
Link to that..
Norbar 17220 HT3 Highwayman 5:1 Torque Multiplier 1300 Nm 1/2" Input 3/4" Output
Completed
Alternatively put torque multiplier in your ebay search...the kits come with handles to work within a truck wheel.
Posted 7 years 3 weeks ago #181747
Torque multipliers, as well as power torque wrenches, are very useful, even essential when you need them.
However the big problem with them all is that:-
  • you need a large space to use them ion front of the bolt
  • You need a strong "torque reaction" point nearby
The torque reaction point is a solid part, that the torque multiplier head can "lean" or "push" against to apply the torque.
Using them on truck wheel nuts is easy, as you have both space and torque reaction points very close to the bolts.
We would often need to get custom fabricated jigs made to provide suitable torque reaction points.
On one pneumatic torque wrench we managed to shear off a 1 1/2 " (1.5") square drive trying to undo one nut!
Trying to find pictures!
by G0RSQ
Posted 7 years 3 weeks ago #181763
I torqued up the head bolts of a Mercedes benz 904 optare solo...I used the multiplier without a reaction point...only to test my new multiplier toy...the head torque was 170nm..+90 degrees+90 degrees...I normally use a 3/4 drive power bar to pull the 180 degrees angle torque...no reaction point ...but just using a 1/2 ratchet ...I could sense the power has the whole engine wanted to spin around....one shout to sam.. my work college. ..he became my reaction point has he held the multiplier with a reaction bar.
Posted 7 years 3 weeks ago #181801
So today I was taking the head of a German man...no...I mean a man engine..I'd just had my dinner so pulling on the metre long 3/4 drive bar wasn't doing my digestion any favours....so out came the torque multiplier. ..that's right let's take it easy...
The bolts came undone as if they were never tight. ...but believe me ...they were...after undoing these tight head bolts I saved a couple just to experiment...if I could undo the head bolts using a every day 1/2 inch ratchet.
The answer was yes..the multiplier made it a doddle...without it ..if I'd used the 1/2 inch ratchet on its own there would of been no chance of undoing the bolts...even with a long extention tube the ratchet would of sheered it's teeth .....the multiplier is amazing...why maul yourself to death...
Pictures show the use of the reaction bar through the lifting eye
Used a pencil just to hold the bar up while I took a photo.
Time to create page: 1.652 seconds
