timing belt change
- mgtfbluestreak
I needed to do it again 4 months later! :oops:
Used an impact gun to tighten.
Now I always use the tool :broon:
Much easier to torque up correctly with a torque wrench.
How does your mechanic friend torque the bolt back up using an impact gun?
- mgtfbluestreak
You can see in the photo the 2 bolts loose and the gap appearing..make sure there's no dirt around mount or you will contaminate the belt
Observe the torque settings and do it has I did ...correct tools all the time..little torque wrench for the tentioner bolt..and observe the way the belt is fed back on..in a anti clockwise position starting from the crank pulley
Keeping the belt tight so not to skip a tooth...a white tippex marker pen is always handy to highlight you timing marks..rotate the engine a couple of times by hand checking the marks are correct is the thing to do before turning the key...I printed the relevant info from my manual and took it into the garage..and followed it to the book apart from reusing the tensioner bolt..which I mentioned before had loctite reapplied...the auto tentioner is easy to understand.
Those two bolts for the end mount that bluestreak should can be a... female dog to loosen if dissimilar metal corrosion has taken place. Do replace those bolts because there is a good chance you will damage the bolt head removing them; they are supposed to be replacement items as per the manual.
G0RSQ's picture of the belt coming off was probably due to the very shallow keyway in the crank gear being misaligned with the notch in the crank pulley; a very common problem. It happened to me and the belt came off due to the crank bolt coming loose, even though it was tightened to the correct torque setting. Be very, very careful to ensure that the keyway on the crank gear and pulley are aligned while you are hand tightening the crank bolt.
[size=10pt]Mark[/size]
95 MGF
- mgtfbluestreak
- mgtfbluestreak
- SundanceUK
Before you start, that is, if you are removing the engine mounting bracket in front of the timing belt cover, give the two bolts a soak with penetrating oil for a few days before.
When mine was done earlier this year, the bolts were solid and the engine mount arm had to be removed and another fitted. Consequently the large rubber mounting bush that the arm sits on to the rear also disintegrated after being disturbed.
Had to replace that too. Looking back at the records my timing belt was far overdue being done 7 years previous, so I was anxious to replace it.
I was fortunate that I took it to Dave and Kayleigh's at Derby, as they had a spare rear subframe with an arm and a spare mount on a scrap ZR that was the same. Took 7 hours to do the full job though.
I only took it there instead of them coming to me as it was raining. I have a good selection of tools and equipment, but I did not have the gear to do this job.
So before you do the belt, just check the bolts are not seized. If they snap off, then its a new arm!
Sundance
- mgtfbluestreak
- mgtfbluestreak
- mgtfbluestreak
It's got a 5:1 ratio tried it on some hgv engines..after torque up...the angle torque required after require some serious pulling on large power bars...but this makes the job a doddle.
