MOT emissions
Replied by Andy Lawrence on topic MOT emissions
Posted 6 years 11 months ago #182130
It could be.
Open the joint and smear some exhaust paste in there.
WHALE OIL BEEF HOOKED
Replied by Tu28 on topic MOT emissions
Posted 2 years 8 months ago #198703
So how did this story end up for Robmj52..? I have a similar problem. Here are my values from the MOT:
CO at 2500 rpm: 0,3 (approved)
CO: 0,2 (approved)
Lambda: 1,46 (! not approved, limit is 1,03)
HC: 541 (! not approved, limit is 200)
Last Edit:2 years 7 months ago by Tu28
Last edit: 2 years 7 months ago by Tu28.
Replied by neilpinleeds on topic MOT emissions
Posted 2 years 8 months ago #198705
I wouldn't think that other than the catalyst the rear part of the exhaust system would have any meaningful impact on emissions?. Surely this is a (over) fueling or ignition issue?
Replied by David Aiketgate on topic MOT emissions
Posted 2 years 8 months ago #198707
:welcome2: Aftermarket cats are notorious for passing 1st year after fitting and possibly second year, but failing after that. This is due to the minimum amount of reactive component within it.
They also usually require to be very hot to pass, again for the same reason. Try to get the tester to do the emissions test immediately after you have given the car a good run.
I went through this almost every year until I fitted a standard MGR type approved cat. The car has flown through the emissions every year since.
Last Edit:2 years 8 months ago by David Aiketgate
Last edit: 2 years 8 months ago by David Aiketgate.
Posted 2 years 8 months ago #198708
Thanks guys
Last edit: 2 years 7 months ago by Tu28. Reason: nobody wants to discuss
Time to create page: 0.528 seconds
