door microswitch
Hi all so it looks like my drivers door micro switch is on its way out, does anyone know where i could get one from ?
by p38
If I'm looking for something small that can't be found cheap on ebay http://www.mgfntfbitz.co.uk/ usually have it.
Last Edit:6 years 11 months ago
by Bob
Last edit: 6 years 11 months ago by Bob.
I would just get another lock mechanism.
By the time you disassemble the lock, test then remove the microswitch, solder in the new microswitch, re assemble the lock you could have changed the lock mechanism a dozen times.
That's if you can get a new switch in the first place.:shrug:
Can concur with David, a new mechanism is needed, but good luck with a new micro switch.
by davidgv1
