LE500 Speedometer in MGF
Has anybody (besides from a shop in Holland) got the TF LE500 speedometer working in their MGF?
im restoring my MGF at the moment , and also make the interior look a bit more modern. so i found the TF LE500 speedometer for a good price (from china)
they also sell the wiring loom. but does anybody know how to fit it in an MGF from 1999?
ive seen some older posts here , but no solution yet.
However I think, as the mk1 F uses cable drive, it isn't straight forward.
- SundanceUK
http://www.metal-monkey.co.uk/rover-mgf.html
Sundance
- adamelphick
I fitted the LE500 pod to my '53 plate TF and there is an issue with the SRS as the NAC TF used a different SRS system. I have the SRS unit from a ZS Mk2 - but not the plug it plugs in to! Been trying to find one for months! If I can find one then I might be bale to make it work properly.
The main issue with the MGF is that you must have a MK2 at least as it has a electric speedo - or you update to the later type, then we have to fix the SRS issue. The garage in holland who doe make them work is very expensive - I know he spent lots making them work, but it is still as much as some of us paid for our cars!
adamelphick wrote: Hi Youri - Welcome by the way!
i know that the shop in Holland also build the LE500 speedometer in a MGF mk1! but they are way to expensive. im not going to pay 350 euros for a speedometer that i can buy for 50 euros! i was hoping that someone in England already succeeded on building one in his MGF mk1
- adamelphick
I think so far no one has done it (unless I am wrong) as it not only involves finding out the wiring changes needed to make it work on a MK2 car (with electronic speedo), but also then converting the F to that style of speedo.
If I can find an 'Mk2 Facelift MGZS' or 'MGTF post 2009' SRS ECU orange plug with some wiring attached then I can match it up to my LE500 wiring diagram and compare it to my Mk2 wiring.. If anyone is at a scrapyard and sees one please grab it for me!
Does the SRS light fail to clear if you fit a 2005 MGR cluster in a SAIC car?
I plan to go back to the older cluster as I dislike the spirally orange lighting....
- adamelphick
Any news on this? I've now got the SRS ECU etc but just not had time to investigate further due to work commitments.yblokdijk wrote: I've got good news for anybody that wants to fit the LE500 speedo in their cars. I've found the person who knows how to clear the srs light on the cars ( its an extra resistor thats needed) soon i will instal one in my MGF mk1 , he says its a simple job , just need the right connector and the resistor. (its not cowa who sells them in holland, its the person that found out for cowa how to do it)
A cheap 'add a resistor' solution would be awesome.
Sent from my CLT-L29 using Tapatalk
All works fine and my car no longer looks like a 90's Vauxhall Nova.....
