LE500 Speedometer in MGF
LE500 Speedometer in MGF was created by yblokdijk
Posted 6 years 11 months ago #182166
Hello ,
Has anybody (besides from a shop in Holland) got the TF LE500 speedometer working in their MGF?
im restoring my MGF at the moment , and also make the interior look a bit more modern. so i found the TF LE500 speedometer for a good price (from china)
they also sell the wiring loom. but does anybody know how to fit it in an MGF from 1999?
ive seen some older posts here , but no solution yet.
Replied by David Aiketgate on topic LE500 Speedometer in MGF
Posted 6 years 11 months ago #182168
Im sure adamelphic has done this successfully.:yesnod:
The following user(s) said Thank You: yblokdijk
Replied by yblokdijk on topic LE500 Speedometer in MGF
Posted 6 years 11 months ago #182171
i hope he can help me with that!
Replied by talkingcars on topic LE500 Speedometer in MGF
Posted 6 years 11 months ago #182182
Search the forum for Adams posts.
However I think, as the mk1 F uses cable drive, it isn't straight forward.
Replied by SundanceUK on topic LE500 Speedometer in MGF
Posted 6 years 11 months ago #182185
Have at look at this
http://www.metal-monkey.co.uk/rover-mgf.html
Sundance
Replied by adamelphick on topic LE500 Speedometer in MGF
Posted 6 years 11 months ago #182187
Hi Youri - Welcome by the way!
I fitted the LE500 pod to my '53 plate TF and there is an issue with the SRS as the NAC TF used a different SRS system. I have the SRS unit from a ZS Mk2 - but not the plug it plugs in to! Been trying to find one for months! If I can find one then I might be bale to make it work properly.
The main issue with the MGF is that you must have a MK2 at least as it has a electric speedo - or you update to the later type, then we have to fix the SRS issue. The garage in holland who doe make them work is very expensive - I know he spent lots making them work, but it is still as much as some of us paid for our cars!
Posted 6 years 11 months ago #182226
adamelphick wrote: Hi Youri - Welcome by the way!
i know that the shop in Holland also build the LE500 speedometer in a MGF mk1! but they are way to expensive. im not going to pay 350 euros for a speedometer that i can buy for 50 euros! i was hoping that someone in England already succeeded on building one in his MGF mk1
Posted 6 years 11 months ago #182302
I think so far no one has done it (unless I am wrong) as it not only involves finding out the wiring changes needed to make it work on a MK2 car (with electronic speedo), but also then converting the F to that style of speedo.
If I can find an 'Mk2 Facelift MGZS' or 'MGTF post 2009' SRS ECU orange plug with some wiring attached then I can match it up to my LE500 wiring diagram and compare it to my Mk2 wiring.. If anyone is at a scrapyard and sees one please grab it for me!
Posted 6 years 7 months ago #184689
I've got good news for anybody that wants to fit the LE500 speedo in their cars. I've found the person who knows how to clear the srs light on the cars ( its an extra resistor thats needed) soon i will instal one in my MGF mk1 , he says its a simple job , just need the right connector and the resistor. (its not cowa who sells them in holland, its the person that found out for cowa how to do it)
Replied by brendanD on topic LE500 Speedometer in MGF
Posted 6 years 5 months ago #186440
How about the other way do round?
Does the SRS light fail to clear if you fit a 2005 MGR cluster in a SAIC car?
I plan to go back to the older cluster as I dislike the spirally orange lighting....
Replied by adamelphick on topic Re:RE: LE500 Speedometer in MGF
Posted 6 years 5 months ago #186442
yblokdijk wrote: I've got good news for anybody that wants to fit the LE500 speedo in their cars. I've found the person who knows how to clear the srs light on the cars ( its an extra resistor thats needed) soon i will instal one in my MGF mk1 , he says its a simple job , just need the right connector and the resistor. (its not cowa who sells them in holland, its the person that found out for cowa how to do it)
Any news on this? I've now got the SRS ECU etc but just not had time to investigate further due to work commitments.
A cheap 'add a resistor' solution would be awesome.
Sent from my CLT-L29 using Tapatalk
Posted 6 years 4 months ago #186613
To update on my initial question, I've now swapped my SAIC cluster, oil and clock for 2005MY MGR versions.
All works fine and my car no longer looks like a 90's Vauxhall Nova.....
Time to create page: 0.664 seconds
