Clock won't keep time
- mgtfbluestreak
If disconnecting the clock from the power doesn't do the trick then it's new clock time has the teeth wear out on these clocks and the minute hand doesn't stay in tune with the hour hand...not a expensive replacement .
- mgtfbluestreak
- John and Sue
just a thought: back in t'day, dash instruments were fed through a ballast resistor/compensating device to ensure accuracy at varying voltage levels: is this still the case does anyone know? I know ballast resistors are usually associated with ignition coils but I recall that Ford instrument resistors, a sealed can bolted to the back of the cluster, failed regularly resulting mainly in fuel gauge reading low. As I said, just a thought.....
- mgtfbluestreak
- mgtfbluestreak
- Leigh Ping
Clock, running slow (Solved). - MG Clock running slow fix.
- John and Sue
- gooseholla
If not, thanks for the links!
John
