Headlights
Headlights was created by The tron
Posted 6 years 9 months ago #183529
First off an apology I'm on mobile I attempted to use the search function and it was no help.
So I have an 03 cool blue. I changed the bulbs in the headlights and they are a bit meh but high beam is dreadful. If I stand outside the car the difference is noticeable but when driving there is almost no change.
Has anyone any suggestions for assitance. Any thing would be much appreciated.
Dan
Sent from my SM-G935F using Tapatalk
Replied by G0RSQ on topic Headlights
Posted 6 years 9 months ago #183533
Headlight strength was never a strong point of the TF, but certainly should not be "bad".
I fitted nightbreakers and there was a small, but noticeable improvement.
Are plastic lenses in good condition and not crazed or cloudy? Will make a big difference.
Are bulbs correctly installed, again can make a big difference (from experience)
Have you had the beam checked and adjusted?
The MOT just checks that they are not too high, so could be low.
If in doubt take to good garage and ask specifically to accurately align the headlights to specification.
by G0RSQ
Replied by The tron on topic Re:RE: Headlights
Posted 6 years 9 months ago #183535
G0RSQ wrote: Headlight strength was never a strong point of the TF, but certainly should not be "bad".
Thanks.
I'll check over everything this weekend.
Thought maybe put LED bulbs in
Replied by John and Sue on topic Re:RE: Headlights
Posted 6 years 9 months ago #183536
I put in Osram Nightbreakers for dip: bargain prices at eurocarparts. Improved. Looking at upgrading the mains: 3a fitment which is a bit rare. H3 apparently fit. On the list......
Try T cutting the lenses to remove any bloom. And inspect the reflectors for deterioration.
Replied by The tron on topic Re:RE: Re:RE: Headlights
Posted 6 years 9 months ago #183538
John and Sue wrote: I put in Osram Nightbreakers for dip: bargain prices at eurocarparts. Improved. Looking at upgrading the mains: 3a fitment which is a bit rare. H3 apparently fit. On the list......
Hi, Thanks for the help.
I "think" the headlights are in really good condition I'll double check at the weekend as I'm away at the moment. I'll look into osrams had them in an old Scooby and they were better than standard.
Replied by David Aiketgate on topic Re:RE: Headlights
Posted 6 years 9 months ago #183539
Not H3 but Hb3.:yesnod:
Posted 6 years 9 months ago #183573
I stand corrected. But H3A rings a bell also. Confused.com. :-?
Posted 6 years 9 months ago #183584
Yeah. The correct bulb is an Hb3a, but osram don't make that fitment. They do make the Hb3, which will fit, it's just that one has the electrical connection at 90 degrees to the bulb and the other is straight. Makes it a little fiddly to connect up but there is enough slack in the cables to do it.
Replied by The tron on topic Re:Headlights
Posted 6 years 9 months ago #183634
So I checked the headlights and they seem clear and fine. I'm going to get the alignment checked by a garage. The high beams however make almost 0 difference to dipped beam
Replied by tnjk on topic Headlights
Posted 6 years 9 months ago #184060
Replacing the traditional bulbs with xenon or LED would give be an improvement I think.
But I am not sure if this is a difficult modification for the TF
by tnjk
Replied by NikTheGeek on topic Headlights
Posted 6 years 9 months ago #184071
tnjk wrote: Replacing the traditional bulbs with xenon or LED would give be an improvement I think.
It's an illegal one...
Time to create page: 0.544 seconds
