retrieval
retrieval was created by graham1
Posted 6 years 8 months ago #184339
going to pick up the car tomorrow, Jason went above and beyond to help me out and brought me all the way home as I had no idea where I was, cannot fault him he even has had a look at my driver's window which was sticking and doing my head in, good man good work, just need to buy two wings later on and the car is finished.:broon: :clap:
Last Edit:6 years 8 months ago by graham1
Last edit: 6 years 8 months ago by David Aiketgate.
Replied by sworkscooper on topic retreival
Posted 6 years 8 months ago #184341
Well done .
John
Replied by graham1 on topic retreival
Posted 6 years 8 months ago #184342
Thanks John :broon:
by graham1
Replied by Fisher on topic retreival
Posted 6 years 8 months ago #184349
Yes totally agree. Spoke to him (John) last week as some bl..dy idiot had welded my near side subframe mount !!!! He has says it can be done, and all I have to do is drink tea in his reception whilst he does it. Cost very acceptable.
Again Top Man.
Regards
Robert
by Fisher
Posted 6 years 8 months ago #184357
Why on earth would anyone weld up a sub frame mount ?
John .
Replied by mgtfbluestreak on topic retreival
Posted 6 years 8 months ago #184358
A subframe mount should be replaced for a new item not welded
Posted 6 years 8 months ago #184360
Let us be honest you do get some right head cases.
by graham1
Posted 6 years 8 months ago #184375
From what I can see (Whoever!!!) was working on the subframe mount one of the bolts snapped (as they doI am told). Instead of drilling and re-tapping they just tack welded the bolt hole. Lazy bast..ds!
It looks, with some delicate angle grinding, the mount can be removed, the snapped bolt dilled out and new mount and s/s/ bolts fitted.
Last Edit:6 years 8 months ago by Fisher
Last edit: 6 years 8 months ago by Fisher. Reason: spelling
Replied by Borypops on topic Re:retrieval
Posted 6 years 4 months ago #186756
sworkscooper wrote: Why on earth would anyone weld up a sub frame mount ?
John .
Beats me
Replied by graham1 on topic Re:retrieval
Posted 6 years 4 months ago #186757
he must have been a rite dick,then again I have senn the anti rollbar brackets welderd, funny realy as he melted the new rubbers doing it, this is a danger to the poor sod who is going to drive it, could have a child with him .:hgf:
by graham1
Replied by Cobber on topic Re:retrieval
Posted 6 years 4 months ago #186766
Looks more like bird shit than a weld!
Replied by mowog73 on topic Re:retrieval
Posted 6 years 4 months ago #186769
I recently replaced a mount on my wife's F that had one of it 'ears' welded to the subframe. Once the mount was removed, I found the broken mounting bolt. When I went to centre punch the bolt, the captive nut let go; no longer welded to the inside of the body mount. The other bolt broke while trying to remove it and that nut let go when centre punching the bolt. I ended up drilling larger holds to the body-portion of the mount and welding new nuts to the body-portion of the mount and grinding the welds flat.
Here's a picture of the mount that came off the car. By the way, you do not have to replace these mounts in pairs as is stated on Rimmer's website. The superceded part is exactly the same as the original.
[size=10pt]Mark[/size]
95 MGF
by mowog73
Time to create page: 0.583 seconds
