handbreak light
handbreak light was created by graham1
Posted 6 years 8 months ago #184565
just one problem how do I adjust the handbrake light switch as when I hit a bump the light flashes been told this is common. :-?
by graham1
Replied by Airportable on topic handbreak light
Posted 6 years 8 months ago #184575
There's a How To Guide for that, it's always worth having a look through when faced with a problem, it's my first port of call.
Replied by graham1 on topic handbreak light
Posted 6 years 8 months ago #184576
:broon: thank you I will go have a look now
by graham1
Replied by John and Sue on topic handbreak light
Posted 6 years 8 months ago #184577
https://www.the-t-bar.com/forum/21-david-aiketgate-s-guides/204-handbrake-light-flickering-how-to-cure-it
How to: From David A.
Remember it's also low fluid warning!!
Last Edit:6 years 8 months ago by John and Sue
Last edit: 6 years 8 months ago by John and Sue.
Posted 6 years 8 months ago #184578
thanks, I have seen it, I will investigate it tomorrow, I think it just wants adjusting so one will just have to get the spanners out and have a bash at it,:broon:
by graham1
Replied by G0RSQ on topic handbreak light
Posted 6 years 8 months ago #184580
When the handbrake light starts flashing over bumps, it is usually the first sign that the handbrake mechanism on the rear calipers is starting to stick, and not allowing the handbrake lever to fully move back down.
Check this first before making adjustments to the switch, as it is an early warning that the calipers need looking at, before they get too bad.
by G0RSQ
Posted 6 years 8 months ago #184581
thank you, I know for sure it is not the rear calipers as I have removed and cleaned them 1 month ago, I will let you know how I got on tomorrow:broon:
by graham1
