rear view camera
just fitted a rear camera as I backed into my Astra, it is a sod to see behind you but all sorted out now,:clap:
Last Edit:6 years 7 months ago
by graham1
Last edit: 6 years 7 months ago by David Aiketgate.
- mgtfbluestreak
- SundanceUK
will take some pic's tomorrow mine is on the rear bumper between the number plate lights, and it comes on my ice when I engage reverse gear, the wiring was a bit of a pig to route through the engine bay but I got there in the end:broon:
by graham1
- El gordo escoces
- Journeyman MGer
Bought a rear view camera from China (less than £40). Works really well . It's fitted in the wee f steptronic
If you look closely you can see the camera just above the first number of the registration
I have the same set up as you will post pics tonight, we must be on the same wavelength as this is exactly the same place I put mine :broon:
by graham1
by graham1
The following user(s) said Thank You: Gerry.laing, El gordo escoces
- mgtfbluestreak
just glad there was no damage, should have fitted one ages ago, at least I won't hit anything else:broon: :broon: :broon:
by graham1
- The driving dutchman
No MOT issue with the camera in front of the license plate?
Verstuurd vanaf mijn SM-G920F met Tapatalk
I hope not, it was a pig to rigg up. wouldn't like to have to take it all apart again,
by graham1
Time to create page: 0.529 seconds
