Centre "popper" on the tonneau cover
- Daleswalker
- Apprentice MGer
Hi guys,
I cannot, for the life of me, get the centre popper to attach when fitting my tonneau cover over my folded hood. I've tried gentle persuasion at differing angles, I've tried brute force and ignorance...Not happening! Is there a knack to it? I've had the motor for a year now (but I work abroad so I've only really driven it a handful of times) and I never fit the cover because of this problem and it looks so much neater with it on!!
by Daleswalker
- SundanceUK
Replied by SundanceUK on topic Centre "popper" on the tonneau cover
Posted 6 years 6 months ago #185275
Its easy to replace, had to do mine recently, they are available from the usual MG suppliers for peanuts...
Sundance
Sundance
by SundanceUK
The following user(s) said Thank You: Daleswalker
- Daleswalker
- Apprentice MGer
Replied by Daleswalker on topic Centre "popper" on the tonneau cover
Posted 6 years 6 months ago #185276
Hi Sundance,
Did you just replace the male half (i.e. the bit attached to the car) or did you have to do both?
Thanks for your reply!!
DW
DW
by Daleswalker
Replied by David Aiketgate on topic Centre "popper" on the tonneau cover
Posted 6 years 6 months ago #185278
Presuming its a mk 2 cover, I fit the sides, then position the apron roll under the opened boot lid. Then drop the boot lid enough to hold the roll in place. Then fix the centre stud and finally close the boot lid. Works for me.:yesnod:
Check that the popper is not damaged by trying it before anything else.
Also make sure the roof is folding down fully. I've seen roofs that sit high when dropped due to twisting of the frame, lack of lubed joints etc.
- Daleswalker
- Apprentice MGer
Posted 6 years 6 months ago #185281
Thanks David,
That sounds like the same routine I use. I can't see any visible damage to the stud but I've ordered a new one from the MGOC anyway. I'll give it a go.
by Daleswalker
- SundanceUK
Posted 6 years 6 months ago #185289
I just needed to fit the center stud on the car, the half tonneau popper was ok.
Sundance
Sundance
by SundanceUK
- BruceTF135
Replied by BruceTF135 on topic Centre "popper" on the tonneau cover
Posted 6 years 6 months ago #185296
Simple problem solving exercise? Try this:
The poppers are all the same and there are three of them on the hood/tonneau cover, one in the centre and one each side that fastens just above the lock in the door frame. You should be able to press any of female parts on the cover onto any of the male parts fixed to the car. A simple process of elimination should tell you whether you need to change the fixed male part or the female part on the cover. They look completely standard to me so I am sure that you'll have no problem getting hold of the parts.
Hope this helps.
Bruce.
Hope this helps.
Bruce.
by BruceTF135
