bottom suspension bolts
bottom suspension bolts was created by graham1
Posted 6 years 6 months ago #185324
anybody know where I can buy new stainless steel bolts for the bottom suspension as the one I have, have past there time.
by graham1
Replied by Airportable on topic bottom suspension bolts
Posted 6 years 6 months ago #185325
Stainless might not be the best material, you have to consider tensile strength.
Replied by graham1 on topic bottom suspension bolts
Posted 6 years 6 months ago #185326
thanks, I will have them if I can find them, can you help thank you.
by graham1
Posted 6 years 6 months ago #185328
If the bolt you are referring to is FB110101 then I would stick to that. The ratio of tread to shank is unusual & if you use an off the shelf bolt of 55mm the shank will not be long enough, the thread will rest in the necked portion of the bottom ball joint & rapidly wearing thus compromising the system. The shank needs to be 35mm long & you will be able to buy a stainless bolt of 70mm to achieve this & cut 15mm off, but in you opinion you are using the wrong material.
Replied by mgtfbluestreak on topic bottom suspension bolts
Posted 6 years 6 months ago #185329
I would look for some new or tidy original bolts...prettiest isn't always the best...cars can be made unsafe by replacing everything for the sparkly stuff.
It is possible to get a high tensile stainless steel but it is only about 75% of high tensile steel
Last Edit:6 years 6 months ago by mgtfbluestreak
Last edit: 6 years 6 months ago by mgtfbluestreak.
Posted 6 years 6 months ago #185330
thanks. but where do I buy them from without emptying my already low pockets?
by graham1
Posted 6 years 6 months ago #185331
Options are.
Mgfntfbitz
We love mgfs
Paul depper
Ebay?
List is endless
Posted 6 years 6 months ago #185334
thanks, are the front the same as the rear bolts?
by graham1
Posted 6 years 6 months ago #185335
thank you found them :broon:
by graham1
Replied by talkingcars on topic bottom suspension bolts
Posted 6 years 6 months ago #185338
graham1 wrote: thank you found them :broon:
Where, got a link?
Posted 6 years 6 months ago #185339
MG and Alfa spares Manchester.
https://www.mg-alfa-spares.co.uk/
Last Edit:6 years 6 months ago by graham1
Last edit: 6 years 6 months ago by talkingcars.
Replied by John and Sue on topic bottom suspension bolts
Posted 6 years 6 months ago #185344
Airportable wrote: If the bolt you are referring to is FB110101 then I would stick to that. The ratio of tread to shank is unusual & if you use an off the shelf bolt of 55mm the shank will not be long enough, the thread will rest in the necked portion of the bottom ball joint & rapidly wearing thus compromising the system. The shank needs to be 35mm long & you will be able to buy a stainless bolt of 70mm to achieve this & cut 15mm off, but in you opinion you are using the wrong material.
Aha! An Injuneer! I did electrical engineering but had to wade thru Modulus deformation of materials etc. Shank v thread length.... Zzzzzzz at the time.
Stainless looks mighty purty but due to chromium content (hard, corrosion resistance property) is often less pref than carbon steel in torque tensile properties.
Time to create page: 0.582 seconds
