K map?
K map? was created by jelly
Posted 6 years 6 months ago #185523
Hi I am hoping to get my TF160 mapped this/next month think higher rev limit and overrun crackle, only has toyo sports stainless manifold and down pipe any commendations of any thing else I need/want to do before remap?
by jelly
Replied by Noz1966 on topic K map?
Posted 6 years 6 months ago #185532
jelly wrote: Hi I am hoping to get my TF160 mapped this/next month think higher rev limit and overrun crackle, only has toyo sports stainless manifold and down pipe any commendations of any thing else I need/want to do before remap?
Hi personally to help with the sound, the crackle, get a sports exhaust. I've got a power flow and it's sounds and responds better !!
by Noz1966
Replied by jelly on topic K map?
Posted 6 years 6 months ago #185534
Thanks I was thinking a back box would help been hoping a "good" one would come up on the bay but been looking for too long now so might have to have a toyo?
by jelly
Replied by SundanceUK on topic K map?
Posted 6 years 6 months ago #185538
I would certainly service the car first, and fit new spark plugs and filters, so the mapping would be done with everything as good as it gets.
K-maps will test everything out when the do the remap and will let you know if you have any valve issues or timing and airflow problems.
Make sure you have premium grade fuel in too.
Be prepared to be pleasantly surprised by the results!
Sundance
Last Edit:6 years 6 months ago by SundanceUK
Last edit: 6 years 6 months ago by SundanceUK.
Posted 6 years 6 months ago #185541
Hope so after driving my Fiat 20VT recently MG seems a bit flat and people seem to rate remap looking forward to it.
by jelly
Replied by talkingcars on topic K map?
Posted 6 years 6 months ago #185545
Are you going for a generic map or a live mapping session?
I would definatly get a sports exhaust and a decent airfilter set up if you don't already have one.
Posted 6 years 6 months ago #185551
Thanks TC any body recommend an air filter, suppose a live map as I am going over ?
by jelly
Replied by g7nbp on topic K map?
Posted 6 years 6 months ago #185552
you wont go to far wrong with a K&N or a Pipercross. But look at an enclosed system, because as the engine bay heats up you end up sucking in hot, less dense air and performance drops off. I ran Hesketh with a K&N on the inlet for quite a while and noticed the problem, so bought a cheap induction kit and used the cannister to enclose the cone filter and ran the corrugated hose down to the side vent.
Last Edit:6 years 6 months ago by g7nbp
Last edit: 6 years 6 months ago by g7nbp.
Posted 6 years 6 months ago #185630
Thanks got any recommendations ?
by jelly
Replied by G0RSQ on topic K map?
Posted 6 years 6 months ago #185638
I was always under the impression that the standard TF airbox was pretty good, with little, or no improvement from "upgrades"
Only improvement was to ensure airbox had the two inlet hoses which take air from "cooler" parts af the engine bay.
Also no exhaust "improvements" made any positive difference to performance, only sound (though a very nice sound at that!)
by G0RSQ
The following user(s) said Thank You: NigelOBB
Posted 6 years 6 months ago #185640
Think your right about the air filter Gorsq.
The TF filter has good enough surface area to let the engine breathe pretty good.
I was looking at filters and in particular induction filters for the mod list a few years back.
What came up on the forums was that most people saw a drop in performance when changing to cone type filters. If fitting one, you would be best to get the type that is tailored for the TF or F with a feed from the air intake.
Sundance
Time to create page: 1.506 seconds
