K map?
I was always in two minds about fitting a replacement one on ex-wifes TF, and in the end we settled for a K&N panel as her Sunstorm was in concorse condition and we tried to keep it as original as possible.
As with many performance mods, once you get past the major flaws the overall gains get progressively smaller and it becomes a little "suck it and see" (I think there might be a pun in there somewhere).
Certainly the main problem is getting enough cold air into whatever filter is used and some pipework into the air vent will help with that. I fabricated a scoop for use in dry conditions on track that collected air from under the car, but was never quite happy with it. It would not have been practical for road use however.
If you really want to get some serious air in the you could always get something like this
And did it make the Earth Move? Not really, although there was a little more urgency & when experimenting with the two filters I found no difference between the standard & the K&N.
Maybe if I had put it on instruments there might have been measurable improvements, however at the end of the day I don't kick it down the road, you can't these days, not around here anyway. If say you lived next to the A49 & could get out early on a sunny Saturday morning then - - - - - - - -.
Airportable wrote: If say you lived next to the A49 & could get out early on a sunny Saturday morning then - - - - - - - -.
.... then you get half a mile and find a convoy of people towing caravans that got up even earlier!
south of here isnt too bad, but north.... hmm
Robin
SundanceUK wrote: Think your right about the air filter Gorsq.
The TF filter has good enough surface area to let the engine breathe pretty good.
I was looking at filters and in particular induction filters for the mod list a few years back.
What came up on the forums was that most people saw a drop in performance when changing to cone type filters. If fitting one, you would be best to get the type that is tailored for the TF or F with a feed from the air intake.
Sundance
I also agree, the original airbox with a twin feed and K&N or Pipercross panel filter
