Mis fire
- Flyingoysters
- Apprentice MGer
Mgtf has developed a misfire
Engine management light does not come on but the misfire is only really there when not demanding fuel or accelerating and more noticeable under 70 mph
Any ideas? Is it drawing air somewhere etc?
I am going to change the fuel filter at the side of the engine anyway, but if it's not this........
Cheers in advance.
Cheers in advance.
You need an obd2 reader oñ it to narrow down the possibilities.
- sworkscooper
Could this be similar to a few folks on here with corrosion between the coil pack and lead . A neighbour of mine who had the same miss recently on his TF had changed his plugs and never gave the connection between the plug lead and coil pack a glance . The corrosion on the lead was the cause .
John
John
by sworkscooper
- mgtfbluestreak
Yes I had a misfire the fault code came up like this...misfire on number 1
Changing the coilpacks around changed the fault shown to misfire on cylinder 3...thus showing me which coilpacks to change.
Last Edit:6 years 6 months ago
by mgtfbluestreak
Last edit: 6 years 6 months ago by mgtfbluestreak.
- sworkscooper
Yep , just like that .:clap:
by sworkscooper
- Flyingoysters
- Apprentice MGer
Thanks all.
Changed the plug leads and main fuel filter while on, misfire gone!!!
Cheers
Chris
Cheers
Chris
- The driving dutchman
Thought this topic was about your girlfriend haha 😂
Verstuurd vanaf mijn SM-G920F met Tapatalk
- mgtfbluestreak
Time to create page: 0.519 seconds
