Boot Badge
When i bought my 2002 TF160 4 months ago the dealer replaced the missing "MG" boot badge with a new one held on by double sided tape. That became loose, (not helped by my wife thinking it was the boot handle!) and yesterday inevitably fell off before i had bought more tape.(i know!) We were visiting the Gaydon museum so whilst near Birmingham i popped into David Manners for a new one. However they said that they can't get them anymore they are only available via Xpart stockists. Now the supplying dealer is one such stockist so can get me a part but i noticed that there are two small holes behind where the badge goes so presumably the originals had "pins" on the back to locate them. Is this so? as if it is and i could get a replacement like that somewhere that would be an improvement on the double sided tape.
Anyone got any ideas?
Norm
They have the 2 prongs.
Looks as if this type was for the f, and the self adhesive ones for the tf.
Looks as if the f type will suit your tf.
- mgtfbluestreak
THe full badge can be as much has £20 upwards.
Pictured below is the full badge...part number dab000160..this I believe is what you need.
Heres a ebay link ...just click on to buy or view.
Thanks again for your help
Norm
- mgtfbluestreak
- sworkscooper
As Mr Bluestreak rightly says the original badge tends to fade . I had this happen to both my MG ZR and my TF so I replaced just the center part with gel type badge inserts which are better . When you get your new badge make sure that the double sided tape is being applied to a clean surface . I found that if the suface was warm also helped the badge adhere to the boot .
I can't remember where I got the gel badge inserts from but if you need the information of the seller I will check the receipt which I will have kept . Let me know if you want the details .
John
Norm
- mgtfbluestreak
- mgtfbluestreak
- sworkscooper
Norm wrote: Sworkscooper: thanks for the info. I have ordered off e-bay already however following bluestreak's advice and hope that when it comes it has the original pins on the back so it plugs in. It had better do as it cost £17! I'll let you know how it pans out.
Norm
Hi Norm . The pins don't actually locate into anything that will help to retain the badge to the boot as I recall . When I replaced mine I thought that the pins would push into plastic lugs as on my old Wolseley Hornet but was surprised there weren't any , just holes .
John :nonod:
- mgtfbluestreak
OK. ..quiz time now above is the wolsley hornet and below is the riley elf....whats the difference?apart from the obvious ones made by riley.below is the riley elf.
- mgtfbluestreak
