braking efficiency
- NikTheGeek
Anyway, I stopped about an inch from the bloke and was grateful I wasn't going any faster.
Other than checking the condition of the brake fluid, would better pads like Green Stuff (or any others you may suggest) make a noticable improvement? It didn't pull to either side, so the brakes must be working with the same efficiency.
Any first thoughts?
thanks
Nick
Since I added braided hoses and fitted a break servo bracket the brake pedal certainly seems better. If it reduces braking distances I don't know! but it does give a more confident feel.
:beer: :beer: Steve.
Even with my four pot brakes, this time of year it is difficult to lock up the front wheels, as the grip from decent summer tires on warm dry roads is pretty good.
However braking should still be good, but does need a firm push on the peddal.
As stevew says a servo brace will help firm up the peddle and mean it needs less distance to travel for same braking effort, but it will not improve the actual braking force (it will just feel better, maybe giving greater confidence) or reduce braking distance.
Braided hoses will have little benefit, if your existing hoses are in good condition (in fact cheaper braided hoses are worse than standard hoses). Again the best they will achive is a firming up of the peddal, and less peddal movement. They will not make the brakes work any better, just give a better "feel"!
Changing the pads to "green stuff" and other high performance pads can help, but they only generely work better if at a higher temp, such as when driving on a track. If you are normally heavy on the brakes then they might give a benefit. Some of the high spec ones will actually be a lot worse than standard pads at cold temperatures!
Best thing you can do to give optimum braking is to regularily service the brakes, clean them, and ensure pads are not sticking. Check disks are not scoring or have any vibration. Use quality pads and disks from reputable manufacturers, and stay away from e-bay specials! Dont forget rear brakes at the same time.
If you really want to improve the braking, then you need to consider "big brake kits", particularily for the rear if you already have AP front brakes.
That and make sure you have some decent tires fitted
I have done the following:-
Servo brace.
New brake hoses.
Fresh brake fluid.
Decent brake pads.
- NikTheGeek
cheers,
NIck
Like the majority of people here, I was also not that chuffed with the stopping power of the braking system, so I went down the road of purchasing, drilled and grooved discs with matching pads.
You know what? They were rubbish, I needed leg muscles like “Swarrzenigger” to stop that machine, unbelievable.
Instead of going for another upgrade, I went for the tried and trusted set of mintex pads and discs. I can only say that the transformation on my machine was unbelievable. Not upto the standard of some of the guys on here, but I suddenly had more confidence in the car. It would stop without standing on the pedal, and, ABS would cut in pretty quickly when I called for it. At least it made me smile and not grimace, and the brown trousers went in the bin.
It may not be the solution for you, or some of the other guys on here, but it worked on my f.
Cheers
Combined with a complete fluid change, greasing the guide pins and bleeding in the correct order should make a difference.
As far as drilled and slotted discs go, they do make a difference in the wet, and on track they do stay a lot cooler, but in the dry on the road, I don't really notice any difference. My discs are M-tech and I usually run with mintex pads on the road.. and as I'm lazy, quite often used to leave them on for events too... They aren't quite as good on track when they start to glaze, but again I found the difference quite small.
The main issue is simply the size of the brakes in general. Upgrades are possible, but then you are look at a wheel change too.
- SundanceUK
Mine is a 160, so comes with 4 pots as standard.
Think replacing the brake fluid is important, I do mine every two years and I am more than happy with the stopping power now.
I had three people pull out in front of me one day last year, so I decided to fit the daytime running lights...it;s not happened since (TOUCH WOOD)! My car is XP grey and its quite camouflaged against tarmac!
Maybe fit DRL's or leave your lights on during daytime may also help to prevent someone taking you out!
Sundance
SundanceUK wrote: ! My car is XP grey and its quite camouflaged against tarmac!
More people pulled out in front of my trophy yellow ZS in 5 years than all the other vehicles I have driven in 35 years put together.
