TF wipers
Not sure where to post this question....but my TF wipers have stopped working, works on manual sweep but not on speed 1 or 2. Thinking it is electrical as opposed to mechanical but where is the best place to start looking? Any help welcome, thanks Martyn
by Martyn18
Have you got the circuit diagram, if not download it from the T-Bar library, that will allow you to see what's going on. The momentary flick can be viewed as the first pass of the two continues functions & if that works I think that would rule out the body control unit & thus point back to the switch mech'. That's where I'd start, give the stalk plug a good tweak first.
by Airportable
Agree with Airp, here.
I had a similar issue, the manual wipe worked, but speeds 1 and 2 would only function after a long delay, hopeless when it rained!!
I replaced the stalk unit and everything went back to normal.
You can replace this unit without removing the steering wheel, airbag unit etc.
Cheers
Cheers
by davidgv1
- sworkscooper
Sent my TF'S pektron to Paul Brown of Technozen and he replaced 3 of the 5 relays that go . Two had been done by previous owner , one of them being the wiper relay and the other was window .
Great guy Paul who knows his stuff with any Pektron issues .
John
John
by sworkscooper
Time to create page: 0.488 seconds
