How to install a brake-servo-bracket?
How to install a brake-servo-bracket? was created by NLpeebee
Posted 6 years 5 months ago #186408
I want to install a brake-servo-bracket, should be simple....
But how to remove the box around the interieur air intake?
I own a 2002 TF135 and its a LHD.
Check the picture, it’s in the red box.
Replied by talkingcars on topic How to install a brake-servo-bracket?
Posted 6 years 5 months ago #186411
You will need to replace the intake with a snorkel intake from a later car.
When I did this I cut the old intake to pieces and removed it in bits.
Posted 6 years 5 months ago #186412
P.S. Hi and welcome to the forum.
Replied by g7nbp on topic How to install a brake-servo-bracket?
Posted 6 years 5 months ago #186413
https://www.the-t-bar.com/forum/25-adamelphick-s-guides/19041-tf-air-intake-on-an-f-how-to-upgrade?start=36
https://www.the-t-bar.com/forum/22-cjj-s-guides/75834-brake-servo-flex-fix?start=36
... and welcome to the forum!
Last Edit:6 years 5 months ago by g7nbp
Last edit: 6 years 5 months ago by psymon.
Replied by David Aiketgate on topic How to install a brake-servo-bracket?
Posted 6 years 5 months ago #186417
:welcome2:
Replied by El gordo escoces on topic How to install a brake-servo-bracket?
Posted 6 years 5 months ago #186419
Hola! :welcome: :clap:
Posted 6 years 5 months ago #186421
El gordo escoces wrote: Hola! :welcome: :clap:
Hola?
Shouldn't it be Hallo?
Replied by graham1 on topic How to install a brake-servo-bracket?
Posted 6 years 5 months ago #186422
:welcome: :welcome: :welcome: :welcome:
by graham1
Replied by mgtfbluestreak on topic How to install a brake-servo-bracket?
Posted 6 years 5 months ago #186426
Replied by sworkscooper on topic How to install a brake-servo-bracket?
Posted 6 years 5 months ago #186432
Hi and :welcome: from John in Pudsey Yorkshire.
Replied by NLpeebee on topic How to install a brake-servo-bracket?
Posted 6 years 4 months ago #186582
Thanks to everybody for reacting to my question.
I studied the links and put the project on long term. (Winter 2018/19)
All instructions are for RHD, mine’s is LHD and due to ABS pump on the same side as the breakservo the flex in the breaklines is a lot less. That makes the project more difficult and now is the 😎 time for driving!
Posted 6 years 4 months ago #186626
Would releasing the ABS pump mounting bolts help?
The following user(s) said Thank You: NLpeebee
Time to create page: 0.574 seconds
