Cylinder liner hieght
Cylinder liner hieght was created by Borypops
Posted 6 years 4 months ago #186689
Ok,so I have removed the liners(don’t let anyone tel you the just push out)
I will order new ones and a shim set as the old ones were low,I know what the liner stand proud should be the trouble is I can’t find any information regarding fitting them the sealing compound that is applied on the ledge of the liner must make a difference to the stand proud plus the shim,
so do you fit the shim to the liner or the block and then the sealing compound or vice Versa,any body know the processes
Replied by davidgv1 on topic Cylinder liner hieght
Posted 6 years 4 months ago #186690
Hi,
Just had a look at the Rover Technical Data info, and according to this you run a 2mm bead of hylomer sealant around the stepped portion of the liner, then press the liner into position until it hits on the shoulder.
Cheers
The following user(s) said Thank You: Borypops
Replied by Borypops on topic Re:Cylinder liner hieght
Posted 6 years 4 months ago #186691
davidgv1 wrote: Hi,
Cheers
Thanks for that,my problem is if I shim the liners to the correct height and then put the sealant in I am guessing it will make them higher
Sent from my iPad using Tapatalk
Replied by davidgv1 on topic Re:Cylinder liner hieght
Posted 6 years 4 months ago #186692
Hi, my guess here is virtually nothing. The sealant will be pushed along the sides of the liner.
Don’t forget that there is a tolerance on the heights, so I would set to middle limit before applying the sealant.
Posted 6 years 4 months ago #186693
Bo, to be sure, can’t you assemble one dry, and measure the height, then assemble one with the sealant and re-measure? This will then tell you the answer that you need. If it is high, you can then remove before the sealant cures and adjust accordingly.
Posted 6 years 4 months ago #186694
Borypops wrote:
davidgv1 wrote: Hi,
Cheers
It’s all irrelevant now,I just went out to clean up the block where the liners go,when I got the gunk of ,cracked block
Posted 6 years 4 months ago #186695
Borypops wrote:
Borypops wrote:
davidgv1 wrote: Hi,
Cheers
Drowning my sorrows now deciding the next direction more money🍻🍺🍸🍷🥃
Replied by David Aiketgate on topic Re:Cylinder liner hieght
Posted 6 years 4 months ago #186703
Borypops wrote:
Borypops wrote:
davidgv1 wrote: Hi,
Cheers
Last Edit:6 years 4 months ago by David Aiketgate
Last edit: 6 years 4 months ago by David Aiketgate.
Replied by talkingcars on topic Re:Cylinder liner hieght
Posted 6 years 4 months ago #186711
At least you found it before going too far.
Posted 6 years 4 months ago #186713
Yep could have been worse
Time to create page: 0.545 seconds
