Citroen washer jets - HELP!
Citroen washer jets - HELP! was created by gooseholla
Posted 6 years 4 months ago #186980
Hello,
I purchased the recommended citroen washer jets and well they barely sprayed past themselves. Took out some hosing, nothing. Put shorter length hose on, no change. Tried thinner tubing - nope, still no improvement. They barely spit out of themselves on to the bonnet. What am I doing wrong?!!!
Regards
John
Replied by SundanceUK on topic Citroen washer jets - HELP!
Posted 6 years 4 months ago #186982
They do spray a lot lower than the original direct jet nozzles.
I thought they would not be good enough, but when you are driving, the jet stream of the car carries the water spray up to your windscreen and you get a reasonable coverage.
Try it, when stationary mine just hit the bottom of the windscreen, but when driving its not bad at all.
Sundance
Replied by Sunlover on topic Citroen washer jets - HELP!
Posted 6 years 4 months ago #186984
Try without the non return valve. There can be quite a restriction there.
Replied by David Aiketgate on topic Citroen washer jets - HELP!
Posted 6 years 4 months ago #186988
Sunlover wrote: Try without the non return valve. There can be quite a restriction there.
That's where mine was restricted. Took it out and threw it away.:yesnod:
Replied by talkingcars on topic Citroen washer jets - HELP!
Posted 6 years 4 months ago #186989
What is the action like at the pump outlet?
I shortened my hose so it goes straight from the tank to the bonnet, fitted a Y rather than a Tee to split the supply in 2 and deleted the elbow so hoses have a gentle bend to the actual jets.
IIRC I think I filled a small amount off the leading edge of the jet surround so it was angled up more.
Replied by sworkscooper on topic Citroen washer jets - HELP!
Posted 6 years 4 months ago #186999
Hi John . Is your washer pump on its way out ?. I say this as my TF had these Citroën jets when I first got the car and found that the motor was rusting to the magnets inside an wasn't spinning fast enough to get water to spray out of the jets .
Replied by graham1 on topic Citroen washer jets - HELP!
Posted 6 years 4 months ago #187009
why upgrade ,just get a new set for the mgtf, i don't know what the fuss is about.:nonod:
by graham1
Replied by G0RSQ on topic Citroen washer jets - HELP!
Posted 6 years 4 months ago #187013
graham1 wrote: why upgrade ,just get a new set for the mgtf, i don't know what the fuss is about.:nonod:
Probably for the same reason you wanted to upgrade yours! ;)
graham1 wrote: just changed the wiper jet washers for an upgraded set, but they only spray the lower half of the wipers, forgot what I did with the ones I took off
Last Edit:6 years 4 months ago by G0RSQ
Last edit: 6 years 4 months ago by G0RSQ.
Posted 6 years 4 months ago #187015
agree,:P
by graham1
Posted 6 years 4 months ago #187017
i found they where rubbish so i bought the mgtf ones and all is well.everyone to their own.
by graham1
Replied by gooseholla on topic Citroen washer jets - HELP!
Posted 6 years 4 months ago #187024
I changed all the hoses so I don't think that is restricted or to do with non- return valve. Might be the pump - only one side of the current MG ones even spray, even after cleaning.
I can see the air would help it reach windscreen more when driving, but what about if I need to clean it while stopped at lights, or MOT time? Might investigate pump next.
Posted 6 years 4 months ago #187025
to be honest mine past the m o t with the jets on, but was not happy so changed them back,could be your pump tho, only cheap.
by graham1
Time to create page: 1.024 seconds
