Subframe mounting bolts specification
Having read a couple of threads on this, I gather the M8 setscrews should be 10.9 grade. Does anyone know if the long M14 bolts ( 110mm or 150mm ?) are also 10.9 grade? if so, they are all available at https://www.westfieldfasteners.co.uk/index.html who look to be very competitive.
by Gavin207
Replied by David Aiketgate on topic Subframe mounting bolts specification
Posted 6 years 3 months ago #187350
The original bolts are all 8.8.
This page from Rimmer Bros might help you.
https://rimmerbros.com/Item--i-GRID018916
Last Edit:6 years 3 months ago
by David Aiketgate
Last edit: 6 years 3 months ago by David Aiketgate.
Replied by Gavin207 on topic Subframe mounting bolts specification
Posted 6 years 3 months ago #187353
Thanks David - should have looked harder. So all are standard 8.8 grade. Makes life much easier, I've got a box of these at home
by Gavin207
- SundanceUK
Replied by SundanceUK on topic Subframe mounting bolts specification
Posted 6 years 3 months ago #187358
Or call MGFnTFbitz up at Glossop, Daz will send you a full set of hardware for the mounts, he keeps all the correct bolts, nuts and washers in stock for most parts of the cars. Probably would have chucked them in at cost price if you buy the mounts from him.
Sundance
Sundance
by SundanceUK
Posted 6 years 3 months ago #187359
Thanks. I’ve already got the mount - the car came with a spare in the boot - now I know why!
by Gavin207
Posted 6 years 3 months ago #187363
Got the big bolt out tonight - it's original I think ( mount was blue and fixing bolts are original pattern). Interestingly its grade 10.9.
by Gavin207
Last edit: 6 years 3 months ago by Gavin207.
Posted 6 years 3 months ago #187386
Picked up a good used replacement bolt today from Martin Smith, it's also grade 10.9, and is 105mm long. I've also worked out that by supporting the body it is just possible to fit the bolt and bracket the right way, i.e. Pointing backwards.
by Gavin207
Time to create page: 0.511 seconds
